New Deluxe 24 - not a great first experience - Snowblower Forum : Snow Blower Forums
 3Likes
post #1 of 19 Old 12-18-2016, 08:20 PM Thread Starter
New England, first storm, maybe 6" mostly fluffy. I like to scrape the pavement, as my driveway is very smooth. This seems way too light in the front end - it just keeps stuttering across the pavement, bouncing the front end constantly. Auto-turn seems to not like scraping pavement either, as it really fought me trying to go in a straight line. Was better if I was turning or curving.
Anyhow. I guess I'll have to get weights. Is there a way to adjust the scraper to less aggressive of an angle so it doesn't want to skip?
kjjb0204 is offline
post #2 of 19 Old 12-18-2016, 08:24 PM
Ariens1976's Avatar
Thanks (Given): 16
Thanks (Received): 11
Likes (Received): 7
Raise your side skids....
Ariens1976 is offline
Likes nwcove liked this post
post #3 of 19 Old 12-18-2016, 08:56 PM
ih8thepackers's Avatar
Location: Lake George new york foothills of the Adirondacks
Likes (Received): 14
I used my new deluxe 24 for the first time yesterday,the skid shoes were not adjusted right,so I had to raise them so the scrapper bar was scrapping the pavement more,because it was leaving too much snow on my blacktop driveway.only thing I noticed was at the end of my driveway was a lot of ice buildup,it was kinda bouncing up and down and I was getting traction,but the rest of my driveway was fine,I love the auto turn seems to work great...I had to re-adjust the shoes this morning because I had the scrapper dragging too much,hopefully I got it right this time,I'll see next snow storm..so my first impressions of
My new Ariens is excellent,hopefully it stays that way,and is reliable for many years to come!!
2005 Ariens 8526/932105(sold)
2017 Ariens 24 deluxe 921045------------------------------
ih8thepackers is online now
post #4 of 19 Old 12-18-2016, 09:16 PM Thread Starter
I had them in their highest position and the scraper bar was indeed in contact with the pavement. So much so, that it kept catching and bouncing the front end up. It doesn't want to glide across the pavement when it's resting on the scraper bar.
kjjb0204 is offline
post #5 of 19 Old 12-18-2016, 09:28 PM
69ariens's Avatar
Thanks (Given): 13
Thanks (Received): 20
Likes (Given): 47
Likes (Received): 52
The scraper bar should not be in direct contact with the ground. You should have the scraper bar1/8 off the ground. The runners will break in on a few storms and the scraper will get closer to the pavement .
Scott
69 ariens
toro 721r
69ariens is online now
Thanks uberT thanked for this post
post #6 of 19 Old 12-18-2016, 09:53 PM
Thanks (Given): 23
Likes (Given): 24
Likes (Received): 16
As Ariens69 indicated, the scraper bar should be at least 1/8" off the ground.
If you have a piece of 1/8" cardboard, just place it under the scraper bar, and loosen the skid shoes until they drop down, and make contact with your level garage surface. Then tighten, and you're good to go.
You'll leave a bit of snow on the driveway, but you'll have the required clearance, and Autoturn should work flawlessly.
Strato is online now
post #7 of 19 Old 12-19-2016, 10:16 AM Thread Starter
That's the problem, I think any snowblower should be able to scrape along the pavement for the cleanest surface and have no problems doing it. My previous two machines could slide right along with the skids raised all the way and the scraper bar taking the weight. Why should I have to make adjustments and buy accessories to get this thing to do the same?
kjjb0204 is offline
post #8 of 19 Old 12-19-2016, 12:22 PM
Thanks (Given): 51
Thanks (Received): 60
Likes (Given): 111
Likes (Received): 90
The single stage machines will scrape the pavement clean. You're going to have wear issues doing that with the 2 stage Ariens.
I understand you don't want to have additional expense, but the poly skids are likely to improve your experience.
Make sure everything is squared up. Ariens has a video covering this.
2014 Ariens 28" 921036 | poly skids | heated grips
2015 Ariens 24" SHO 921038 | ARMORskids
uberT is online now
Likes 43128 liked this post
post #9 of 19 Old 12-19-2016, 12:51 PM
Thanks (Received): 82
Likes (Given): 126
Likes (Received): 260
Be sure that your tires are equally and well inflated as that will also cause it to pull one way and seem awkward - but yeah, a 1/8" difference from the shoes and scraper bar is about right on adjustment. The poly skids are also very nice to have.
post #10 of 19 Old 01-08-2017, 10:48 PM Thread Starter
Again today, this snowblower doesn't want to scrape the pavement without bouncing and leaving little piles of snow. Why do I have to spend more $$ and add weight to this to get it to do what I want? I do NOT want to leave 1/8 of snow on the ground. In New England, that turns into a sheet of ice for the rest of the winter. No thanks. I sold my 8-year-old craftsman thinking I was upgrading but that would scrape right along the pavement with no issues, ever. The dealer is going to need to do something here because I am just not happy with this performance at all.
kjjb0204 is offline
Human Verification
