Ariens Deluxe 28 not running at full throttle - Page 2 - Snowblower Forum : Snow Blower Forums
 2Likes
post #11 of 19 Old 02-17-2017, 12:24 PM
jtclays's Avatar
Thanks (Received): 108
Likes (Given): 62
Likes (Received): 167
Not saying you didn't, but is the throttle turned correctly? I know the new AX/LCT's have a ring below the choke to accomplish throttle position. Maybe turning with gloves, not quite catching right, or turned the wrong way. Just looking for an easy answer for you. High octane gas is to avoid knock/detonation in high compression engines. Some places sell their high octane as the only non ethanol infused fuel so why some buy it. 87 e10 should run perfectly fine in any LCT engine.
Thanks dmm2002 thanked for this post
post #12 of 19 Old 02-17-2017, 01:53 PM
Thanks (Received): 24
Likes (Given): 7
Likes (Received): 56
Higher octane gas isn't harder to burn, it's resistant to pre ignition. Any properly operating ignition system will produce a hot enough spark to ignite any pump gas.
Using anything other then regular (87oct) it's technically a waste because the compression ratio is so low on these small engines that higher octane fuels are not nessesary.
The arguement for higher octane fuels is that they likely have better or more detergents and will age better since octane is lost over time.
As for your running condition. It can't hurt to remove the spark plug and check the gap and inspect for crack in the porcelain. Never know if it was dropped for it was installed. You haven't run it for too long but see if it's wet or fouled.
Honda HSS928atd
MTD Gold 826
Simplicity 520
Toro Powerlite
drmerdp is online now
post #13 of 19 Old 02-17-2017, 04:31 PM Thread Starter
Thanks (Given): 7
Just came back after starting it up again, and on pulling off the choke knob to ensure it was seated properly, I found the ring you're referring to. And damned if it wasn't turned all the way down. Cranked it up and off it went. Must have unknowingly turned it down after running it the first time.
Bruised ego aside, finding the problem was my own idiocy is a much easier solution than running back and forth with HD and the local warranty service shop.
Thanks everyone for the suggestions!
Fred9 and RedOctobyr like this.
dmm2002 is offline
post #14 of 19 Old 02-17-2017, 06:13 PM
Thanks (Given): 19
Thanks (Received): 56
Likes (Given): 50
Likes (Received): 121
Awesome, that's great! I'm glad it was an easy fix. Thank you jtclays, I've never used the newer engines, I had no idea there was a weird throttle setup.
I'd still suggest fuel stabilizer for going forward, though.
Toro Powercurve 1800
RedOctobyr is offline
post #15 of 19 Old 02-17-2017, 08:00 PM
Thanks (Received): 95
Likes (Received): 217
Look at it this way, you will never make that mistake again. There are however, about 43 other mistakes that can be made that you haven't yet discovered.
Work fascinates me.
skutflut is online now
post #16 of 19 Old 02-17-2017, 08:16 PM
jtclays's Avatar
Likes (Given): 62
Exactly, like when all the tree hugging, shoveling neighbors are out and you attempt to pull start your shiny gas guzzling beast of a blower several times only to realize the run/off switch is..............definitely off.
post #17 of 19 Old 02-18-2017, 03:47 AM
GoBlowSnow's Avatar
Thanks (Received): 45
Likes (Given): 47
Likes (Received): 117
It was a very poor design to have the throttle and choke knobs integrated onto each other like that. I don't like it myself. That and the crappy gas caps were my only 2 complaints.
GoBlowSnow is offline
post #18 of 19 Old 02-18-2017, 10:33 AM
Thanks (Given): 11
For what it's worth, I have a new Ariens 24 Platinum and the design of the throttle "ring" under the choke is not great. I'm also finding the sticker at that location is lifting because of the regular turning of the choke and turning of the throttle ring with gloves on. The machine is a beast and performs great the 1/2 dozen times I've used it over the last couple weeks.
Also, when I was researching which blower to get, I was at a local dealer and talked to a customer who came in to get advice on the exact model I now have that he previously purchased. He said it starts but would not blow snow very much. Both the dealer and myself told him to check the shear pin but after seeing this design, my guess is he didn't have the throttle turned up to full.
Bob
Ariens 24 Platinum model 921050 with Poly Shoes
Sold my 17 yr old John Deere 828D for $300 in Jan 2017
outrag1 is offline
post #19 of 19 Old 02-18-2017, 01:10 PM
My on/off switch is a mini rocker, mounted low on the block obscured by cables and handlebars and whatever else they could use to hide it. It has microscopic lettering on it indicating the ON OFF positions. I have to get down on my knees and take my glasses off to peer at that little bugger to make sure its ON. I do seem to remember not checking that once in a while during the first winter. Now i just shut off the fuel valve and let it run out of gas while i sweep the snow off it.
Work fascinates me.
Human Verification
