Ariens Auto-Turn Adjustment - Page 2 - Snowblower Forum : Snow Blower Forums
 5Likes
post #11 of 162 Old 01-18-2014, 09:25 PM
JRHAWK9's Avatar
Likes (Received): 9
Originally Posted by uberT View Post
But, with minimum wage workers, and a less-than-concerned attitude, you know what can happen
exactly, again, why I refused to purchase one already "setup". I didn't want to buy one in which somebody else had the opportunity to screw something up on it and then all of a sudden it becomes my problem. Been there, done that.
JRHAWK9 is offline
post #12 of 162 Old 01-20-2014, 02:06 PM
Thanks (Given): 58
Thanks (Received): 62
Likes (Given): 125
Likes (Received): 98
I performed this chute-to-body re-alignment on my MTD machine this morning. It was identical to the Ariens machine pictured in the video I can't believe the adjustment was so quick/simple I've been wrestling with that thru 6 yrs of ownership. Aligning the skids now is child's play. Machine now sits square on the ground for the first time.
2014 Ariens 28" 921036 | poly skids | heated grips
2015 Ariens 24" SHO 921038 | ARMORskids
uberT is online now
post #13 of 162 Old 01-23-2014, 09:14 PM
Ariens hydro pro's Avatar
Likes (Received): 8
Ariens, can your engineers look at the auto turn feature? It's easy to turn the machine around at the end of the driveway, but it is annoying at times going down the driveway. The machine hits a little resistance on 1 side and it unlocks a wheel making it start to turn or fishtail.
Can you guys add a lock out feature to the auto turn? Or at least make it less sensitive. I find the platinum 30 machine I just bought somewhat difficult to snowblow going straight down the driveway. Personally, I won't purchase another with this current auto turn feature. I just don't care for it.
Is there a way to adjust it to make it less sensitive? The fish tailing is annoying!
Thanks.
Ariens hydro pro is online now
post #14 of 162 Old 01-23-2014, 11:25 PM
Thanks.
You are not alone with the problem of fishtailing, whatever name we give the problem it boils down to sharply going off course to the left, or right as the case may be, and after you straighten it out it almost immediately it happens again. Requiring the operator to make constant forced course corrections. A process which grows tiresome rather quickly. It's more problematic for some then others as asphalt surface conditions and compacted snow play a large part in just how bad it can get. Down hill, as in my case can be especially trying to deal with.
I switched to the Ariens brand plastic type of skid which at 1st blush seems to have mitigated the problem somewhat. The jury is still out though, I need more snowstorm time to see what difference they really make. Perhaps if you were to try the plastic type skids we could compare notes.
docfletcher is offline
post #15 of 162 Old 01-24-2014, 05:55 PM
Likes (Received): 8
I'm tempted to modify the skids and install small bearings on a shaft welded to the skids. This would act as steel wheels that won't wear out but simply roll down the driveway or sidewalk.
Years ago my uncle put a set on my dads snowbird machine. That home made steel bearing skid out lasted the machine. When I junked that then 35-ish old machine I should have pulled the wheels off of it. It would look great on the Ariens...
post #16 of 162 Old 01-24-2014, 06:29 PM
I had made a call and talked to tech dept at ariens. I will say Im impressed with customer service with who I spoke to.i told him my experience which is only one time.they are sending poly skids for me to try .which I had ordered armour skids but havent received them yet.if we ever get some more snow il try both out.i am hoping skids will be the cure for my problem.
throttlejunkie450 is offline
post #17 of 162 Old 01-24-2014, 08:21 PM
Throttlejunkie450, who did you talk with at Ariens support?
post #18 of 162 Old 01-24-2014, 08:25 PM
JRHAWK9's Avatar
Likes (Received): 9
I will concur with what throttlejunkie450 said. I've contacted Ariens a few times regarding different topics and every time they have been a pleasure to work with and talk to.
JRHAWK9 is offline
post #19 of 162 Old 01-24-2014, 10:58 PM
On Ariens online chat support I have talked with Joy, Greg and Richard. On the phone just Richard. They were very professional customer service pros.
post #20 of 162 Old 01-24-2014, 11:00 PM
Nforesir's Avatar
U can carry out a live chat on their web site, I talked to Richard a few times, he was very helpful.
The Nforesir
2014 Ariens Deluxe 24
Nforesir is offline
Human Verification
