Hi there
My name is Dan, i'm from norway. and for about six months ago, i bought myself a good old Snowblower. its from the 80s somwhere, its an ST825 925050 type (serial: 014036) starts easy and look great to be that old.
however, since its old, its inevitable that it has some issues. some i've located and are about to adress.
i have som problems with the propulsion. the fricion disc looks OK. and it binds good when lever is depressed. so the problem was probably with the belts
took the belt cover off, and sure enough. the belt is a bit slack. belt does not look very new, so i'm replacing that. but i also found that the idlerpulley is somwhat sloppy aswell. trying to getahold of parts. but almost impossible to get good help here in norway for this issue
looks like i need a new spring for the idler pulley tension and a new idlerpulley and belt. found a company online who has most of what i need (they don't answer my requests, **** them)
all these are easy fixes, new belts, both idlers and a new idler tension spring, and i think i've sorted the propulsion problem.
however, the main reason for me to sign up here and ask question is this:
I've got some problems with throttle linkages. the spring that sits on the top of the butterfly valve keeps popping of, and the blower starts revving like crazy. i reset the spring. and then it pops of again. is this spring available for me to buy somwhere? or do i need to get a replament carb?
and, my throttle cable gets stuck whenever its cold. so i've taken that of to properly dry it (should be replaced, but can't find it anywhere)
and in the process of taking of the cable, i kinda broke the mounting that the cable sleeve sits in under the throttle arm on the control console.
all in all, i chose to buy a good used Ariens blower isntead of these cheap china blowers that infest the markets around here. i rather buy good old quality that i can possibly get new parts for, then a china model which you can't get any spare parts for
sorry if this became a long post. but i'm kinda lost here right now. its in the middle of the season, and i want it to work right (i've gotten allergic to the showel now)
Thanks a bunch for any replys. i can take som pictures if you want to see aswell
Dan
Edit: don't mind my typos here and there. english isn't my daily language
Dan
