Looking for help. Scag hydro walk behind - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 03-05-2016, 04:57 PM Thread Starter
Likes (Received): 6
If this is not appropriate to post here let me know.
I bought a used scag 36" hydro walk behind. Someone put a Kawasaki 12.5 HP engine (FB460) to replace the original Kawasaki 14 hp but the job was not complete. The engine is already in place and it runs fine. The wires are not connected.
Here are my questions
1. I found only one wire coming out of the engine. It turned my test light on when connected to it. Is this the kill wire also? Can I ground this wire to kill the engine?
2. The mower has a electrical PTO. When I connect the two wires from the PTO to a car battery it engages but I can still turn the pulley with my hand. It is tight but can still be turned. Is this normal or does it need to be replaced?
3. When I connec the PTO to the engine wire I mentioned previously, it does not engage. Does it mean the engine does not generate enough current?
Thank you for your help.
bcjm is offline
post #2 of 9 Old 03-05-2016, 06:34 PM
Thanks (Given): 392
Thanks (Received): 454
Likes (Given): 2530
Likes (Received): 859
With the battery hooked up to the PTO and engaged you shouldn't be able to get the pulley to slip. If you're turning the pulley the crankshaft should be locked to it.
Might need to adjust the air gap of the PTO clutch.
That FB460 is a common JD rider engine (I have one in the JD 160) so you might want to try MTF as the folks there would be more familiar with the engine.
Tractor Forum : MyTractorForum.Com Tractor Forums
What color is the wire coming off the engine ??
The engine should have enough current to power the PTO and charge a battery. It should have a regulator mounted somewhere on the Scag. Does the Scag have a mount for the battery ??
You may need to pull the flywheel off but there should be a kill wire and a charging wire.
The kill wire is external of the flywheel and once you pull the shroud you can see it attached to the coil. The charging lead will be coming from under the flywheel.
On the JD riders there was a "fix" for the starter not working/engaging properly. Due to the length of wire and the safeties you install a relay at the starter solenoid so the solenoid gets a stronger jolt of voltage and better operates the starter.
If you find you're hitting the key to start it a number of time to get it to kick in it's now a bad starter or low battery, might need the relay.
I just used a generic relay like for fog lights and my own wire. JD want's up to $200 to "fix" the problem at the dealer.
http://www.mytractorforum.com/215-jo...lem-fix-4.html
post #3 of 9 Old 03-05-2016, 06:43 PM
Thanks (Given): 67
Thanks (Received): 199
Likes (Given): 130
Likes (Received): 552
Here is where you want to go. Our parent forum. Walk Behind Mowers - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Toro 5/21
Ariens Sno Tek 7/24
Old green plastic snow shovel
post #4 of 9 Old 03-05-2016, 06:46 PM
Thanks (Given): 392
Likes (Given): 2530
This is how my leads are.
post #5 of 9 Old 03-06-2016, 12:36 AM Thread Starter
Likes (Received): 6
I registered but never got the activation email. I have contacted the forum. Hopefully they will resent.
My mower does not have a battery. It is a pull start version. I am just worried that engine does not generate enough current to engage the PTO without a battery.
The wire I found is white.
bcjm is offline
post #6 of 9 Old 03-06-2016, 11:18 AM
Thanks (Given): 392
Likes (Given): 2530
To the best of my knowledge I'm pretty sure you need a battery for the PTO to work properly. I'm basing that on the fact I haven't seen any rider with an electric PTO that didn't' have a battery. If you were to idle it down I'm sure even if the charging system could run it at WOT the PTO would start slipping and drop out if you tried to idle it down with the PTO engaged.
The pull start or electric doesn't make a difference other than a pull start model might not have, or might not have as big a charging system installed due to the pull start engines original application. Do you know what that engine came off of ??
Have you tried to pull the shroud off the engine to see if your one wire goes to the coil yet ??
post #7 of 9 Old 03-06-2016, 03:40 PM
Thanks (Given): 90
Thanks (Received): 223
Likes (Given): 294
Likes (Received): 330
Maybe you can find the manual here and it may have an answer for you ?
Scag SWZ - Operators Manuals and Parts Lists - Scag Power Equipment
YSHSfan is online now
post #8 of 9 Old 03-06-2016, 04:00 PM Thread Starter
Likes (Received): 6
Thank you for all the information. Appreciated.
bcjm is offline
post #9 of 9 Old 03-07-2016, 09:09 AM Thread Starter
Likes (Received): 6
I found that many mowers have electrical PTO but do not have a battery. The power from the engine goes through a regulator/capacitor first before reaching the clutch.
The only wire from a pull start Kawasaki 12.5 HP engine looks like this( I still don't know how to insert an image in here). I think the wire goes to the engine switch to be grounded has voltage.
bcjm is offline
Human Verification
