Running the gas down - Snowblower Forum : Snow Blower Forums
 4Likes
  • 1 Post By drmerdp
  • 1 Post By Saewoody
  • 2 Post By Loco-diablo
post #1 of 10 Old 04-18-2017, 01:29 PM Thread Starter
Send a message via AIM to Spideriffic
Hello - I ran the machine today to try to burn the remaining gas in the tank. It ran a half hour, then stopped. I started it up again, ran for awhile, then stopped. Repeated numerous times. Now it will no longer start, but I still see fuel in the tank. Why? Isn't it refusing to start because it no longer is receiving fuel? If so, why didn't it use the last of the fuel in the tank? What should I do?
Spideriffic is offline
post #2 of 10 Old 04-18-2017, 01:39 PM
Thanks (Received): 28
Likes (Received): 64
Not sure what engine this is in regard to. You can't run the tank completely dry because the pickup is slightly higher the the base of the tank.
The easiest way to remove all the fuel from the tank is to use a suction device to suck out the residual. Home Depot sells an inexpensive tool called the liqui-vac.
Spideriffic likes this.
Honda HSS1328AATD
MTD Gold 826
Simplicity 520
Toro Powerlite
drmerdp is offline
post #3 of 10 Old 04-18-2017, 02:54 PM
Thanks (Received): 95
Likes (Received): 221
You may see a bit of residual fuel in the bottom of the tank after running the machine out of gas. I just got through draining mine, first with a siphon, to get most of the fuel out, then running it until it quit, about 5 minutes.
I then rolled it out in the sun, loosened that gas cap, but left it on the filler neck to keep dirt from getting in, and left it for the afternoon. When I rolled it back into the garage, the tank was dry from evaporation.
Work fascinates me.
skutflut is offline
post #4 of 10 Old 04-18-2017, 09:19 PM
Thanks (Given): 60
Thanks (Received): 63
Likes (Received): 98
Harbor Freight is another source for cheap hand pumps. I've got one and it works quite well for this task.
uberT is online now
post #5 of 10 Old 04-18-2017, 09:55 PM
GoBlowSnow's Avatar
Thanks (Received): 46
Likes (Given): 47
Likes (Received): 117
Just take the gas cap off and let the stuff evaporate over a few days.
GoBlowSnow is offline
post #6 of 10 Old 04-19-2017, 08:31 AM
Thanks (Received): 7
Likes (Received): 16
I use the Harbor Freight red suction pump to get most of the fuel out, then use a turkey baster and let the rest evaporate. If you have a steel tank you can also shoot some fogging oil into it as best you can to prevent rust.
dhazelton is offline
post #7 of 10 Old 04-19-2017, 09:40 AM
Thanks (Given): 111
Thanks (Received): 122
Likes (Given): 679
Likes (Received): 207
I've used a few siphons and the one I picked up from TSC a few weeks back is the best so far. It has a big primer bulb, check valve and a filter. very nice.
if you have a fuel shut-off...what I often do is shut-off the fuel shutoff, disconnect the fuel line and hook-up a temp fuel line for transfer.
then you can disconnect the fuel line @ the carb & blow some deep creep or seafoam through the fuel line to remove any residual fuel.
('95 Ariens ST724)
classiccat is online now
post #8 of 10 Old 04-19-2017, 08:10 PM
Thanks (Given): 10
I used to empty all my seasonal equipment gas tanks. But I stopped doing that several years ago. I put Startron fuel stabilizer in all my equipment. It all gets stored that way and always starts on the first or second pull when I take it back out. All my stuff runs better and starts much more reliably than before I was using Startron.
RIT333 likes this.
Saewoody is online now
post #9 of 10 Old 04-19-2017, 09:40 PM
Thanks (Received): 24
A friend suggested using Startron a while ago, and that was great advice. Haven't had an issue with small engines since then. I also follow your storage process with similar results.
RIT333 is offline
post #10 of 10 Old 04-19-2017, 10:03 PM
Thanks (Given): 13
Thanks (Received): 17
Likes (Given): 35
Likes (Received): 29
I do the opposite. I add some marine stabil then top off the tank. I then run the engine for 5 or 10 minutes. While running, I shut off the fuel valve and let it run until the engine starves. Then I loosen the drain nut on the bottom of the carb to drain the bowl then retighten the carb nut. I leave the fuel valve closed. Done. I've been doing this for years and have never had a fuel related issue come start up next winter.
GoBlowSnow and The Q like this.
250cc B&S (1150 ft lbs)
Loco-diablo is online now
Human Verification
