Running on choke - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 03-04-2013, 07:01 PM Thread Starter
Running on choke
I have a John Deere walk behind 1028e that will only run on half choke. I've had it at local dealer for this issue with no results. He cleaned the carb and changed plug, but no luck. Any help would be much appreciated.
marreque is offline
post #2 of 8 Old 03-04-2013, 07:11 PM
Thanks (Received): 50
Likes (Received): 98
Choke issue
First off Welcome to the forum.
On your issue, alot depends on engine, model etc. Give some more details or pictures would be very helpful. Sounds like it's in the carb, whether it's been worked on already or not.
HCBPH is offline
post #3 of 8 Old 03-04-2013, 07:13 PM
CarlB's Avatar
Thanks (Received): 26
Likes (Received): 52
If the engine is running on half choke then it is starving for fuel. Either there is a clog from the tank to the carb, the needle is sticking, the float is adjusted incorrectly, the carb is dirty or mis-adjusted, or you have an air leak between the carb and manifold or the manifold and engine. I would check for an air leak first because it is the easiest to do, followed by a fuel flow check from the tank. If both of those fail then the carb needs to be gone through again. carl
CarlB is offline
post #4 of 8 Old 03-04-2013, 07:40 PM Thread Starter
Briggs & Stratton snow series 14.5
marreque is offline
post #5 of 8 Old 03-04-2013, 07:41 PM
td5771's Avatar
Likes (Received): 55
I have rebuilt many Carbs and if it is the emissions style carb with no adjustable jets they sometimes will only run with a liittle choke.
If it was a reg adjustable carb a small turn of the jet screw would fix it.
I have done some emissions and they have the proper power and run well under half choke.
Find out if the shop did a carb clean out or a real rebuild where they pulled the welch plugs and soaked the carb for a few days.
That would make all the difference
Or a replacement carb
td5771 is offline
post #6 of 8 Old 03-04-2013, 07:43 PM Thread Starter
I think it's a Nikki carb??
marreque is offline
post #7 of 8 Old 03-04-2013, 08:34 PM
td5771's Avatar
I am not too familiar with them. A couple pictures of the carb and we would see if it is adjustable or not.
Regardless of what kind it is if it was just cleaned out and not rebuilt with a soak then it is still dirty jnside
td5771 is offline
post #8 of 8 Old 03-04-2013, 10:46 PM Thread Starter
It's non adjustable.
marreque is offline
Human Verification
