Honda, Ariens, or Husqvarna?? Need help!!! - Snowblower Forum : Snow Blower Forums
post #1 of 20 Old 10-21-2013, 05:29 PM Thread Starter
I am new to the site and to snowblowers.
I recently bought a house up in the hills of Connecticut. I have a 500' driveway and I'm looking for some advice on snowblowers. I don't have the funds for a decent truck w/ a plow, so a snowblower is going to be the way to go for me. From my research, I understand that Honda is the top of the top, Ariens is 2nd, and that Husqvarna is a very respectable brand. I've had my eye on the Ariens Pro 36 and recently looked at the Husq. 1650 EXL. Is there a big enough difference between those two to justify the $900 difference in prices?
I also came across a used Honda 1132TA. I'm not sure of the year, but it's going for $2,300. Should this be in the consideration?
Is there another brand that I should consider?
I have to stay under $3,000, which is a lot of money to me, and I just want to make sure I get something with plenty of power, that runs consistently, and will last for a while.
I appreciate any feedback, thank you!!
reabilly44 is offline
post #2 of 20 Old 10-21-2013, 05:38 PM
Thanks (Given): 35
Thanks (Received): 218
Likes (Given): 77
Likes (Received): 415
Well, in the $2,000 to $3,000 range you are definitely in the "Cadillac end" of the scale..which means pricey, but very good quality and reliable machines, that should last you 40 years easily..
500 feet is a good length..An Ariens Pro model would serve you well.
I dont know enough about Hondas to know if that is a good price or not..
Can you determine the exact model year, from that we can get its age, see what a comparable *new* Honda would go for, and that would give us a better idea of the used machines true value..
No!
In fact, I would drop Husqvarna from the list, and stick with $2,000 to $3,000 Hondas or "Pro" series Ariens only..either will serve you very well..then it comes down to just specific features you want, or dont want, and price.
post #3 of 20 Old 10-21-2013, 06:15 PM
Thanks (Given): 67
Thanks (Received): 199
Likes (Given): 130
Likes (Received): 552
Try to avoid the husqvarna. Toro makes a 28" 11 hp you miight want to check. In the 2k price range. Good products.
Toro 5/21
Ariens Sno Tek 7/24
Old green plastic snow shovel
micah68kj is offline
post #4 of 20 Old 10-21-2013, 06:50 PM
Thanks (Given): 169
Thanks (Received): 246
Likes (Given): 974
Likes (Received): 409
scratch the husy off the list! have you thought about a riding mower with a plow or snowblower attachment or both
2-toro 521E-38052
1-.............,TORO XL 624..............
1-............, TORO XL 824..............
post #5 of 20 Old 10-21-2013, 10:17 PM Thread Starter
I don't know much about riders, but I have a pretty steep grade on my front lawn, steep enough to have to go up and down, not side to side. I looked at a Husqvarna R322T, a new model to the US. It looks like it'd be great for mowing, I'm just not sure how it would do with the snowblower attachment.
I would prefer to have a rider with a snow blower attachment, but I think anything that would work well would be out of my price range. I'm open to suggestions.
post #6 of 20 Old 10-21-2013, 10:27 PM
Thanks (Received): 179
Likes (Received): 212
Have you considered looking for used? Not sure what your mechanical level is, but used is a good bet, especially if they need work. Do you have the storage space to keep a spare rider dedicated to snow blowing only?
post #7 of 20 Old 10-22-2013, 07:45 AM
sr71's Avatar
....I've had an 1132 for almost 10 years now ..Honda has made a few improvements and now calls it the 1332. As noted you will be hard pressed to find a better unit. Don't know what a 1332 goes for now but offer them $1700....be prepared to settle at $2000.
Kindest
Kevin
Honda HS 1132
sr71 is offline
post #8 of 20 Old 10-22-2013, 08:21 AM
pfn
Thanks (Given): 13
Likes (Received): 11
All-in all I'd say the Honda is the better unit because of the hydrostatic transmission. That said if that transmission breaks you are looking at BIG bucks. The Ariens trans... 1/10 the cost (at most) and it is a very simple fix. The axiom, KISS, comes to mind.
pfn is offline
post #9 of 20 Old 10-22-2013, 08:44 AM
GustoGuy's Avatar
Thanks (Given): 42
Thanks (Received): 58
Likes (Given): 49
Likes (Received): 75
I would agree with Scot in recommending Ariens brand. I would say a Platinum or Professional grade Ariens would be perfect for you. Since you have a 500 foot driveway you should be looking at minimum 32 inch or better. Plus Ariens has the Zero-Turn technology transmission so you can turn it around effortlessly in the machine's own foot print. Honda like wise is also a great machine but very expensive. Stay away from track models unless you have a real steep driveway or one with loose gravel in which you would need the extra traction. Replacement tracks can be very expensive after the warranty period runs out. Post a picture and a description of which machine you end up getting. As to Honda. Yes they are nice but I was looking at their website and their most expensive Commercial tracked blower is model HS1336iAS at $7999 . Wow that is some money.
Mark
GustoGuy is offline
post #10 of 20 Old 10-22-2013, 11:10 AM
robert@honda's Avatar
Thanks (Received): 214
Likes (Given): 36
Likes (Received): 215
HS1132 was updated to the HS1332 two years ago. The "13" has slightly different engine, taller handlebars, extreme cold-weather/anti-icing kit now standard, and individual choke and throttle controls. MSRP for the "13" is $3,189 for the pull-start model, and $3,399 for the electric (120V AC) start.
Other specs are identical, including the 3-year warranty.
If you'll share the serial number off the HS1132, I can tell you if any warranty is remaining, and when/where it was sold.
More at the Honda website: Honda Snowblowers and Snow Throwers
Robert@Honda
Social Media Consigliere
robert@honda is offline
Human Verification
