HSS928 governor adjustment question and bog under load issue - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 02-13-2017, 11:17 PM Thread Starter
Hi all,
I have a new HSS928AWD, my first Honda snowblower. Given that these are considered the Cadillac of blowers I had high expectations...and seriously let down. My problem is that the machine bogs down under what I would consider light loads. I am limited to the bottom 1/4 of the forward speed adjustment at just 5-6" of snow (not packed or slush, not super fluffy...just regular snowfall). It throws snow to the moon, but it seems to hit a limit prematurely and I have to back off. Half bucket height or more and I have to set it to the slowest crawl possible or it will stall out. I have a older, basic box-store MTD which would easily move faster thru this stuff than the Honda.
I have searched thru the forum and saw that the chute on these is a bit of a limiting factor. It doesn't appear to be the major cause in my case, but i suppose it's not helping either.
I started down the troubleshooting list and had a specific question about the governor. How much free rotation should the governor arm shaft have? This is the part which comes out of the engine case. The adjustment procedure involves loosening the governor arm, rotating the shaft counter clockwise as much as it will go, then securing the arm. The shaft only has barely 10* of movement to begin with. I don't believe this is normal - i think it should turn a lot more than that. Anybody confirm what sort of arc the shaft can turn?
Open to other feedback about the bogging, but I suspect governor or carb. Manual also suggests compression, valves, and plug.
keeena is offline
post #2 of 7 Old 02-15-2017, 12:47 AM
Thanks (Received): 22
Likes (Given): 7
Likes (Received): 40
Do you have access to a tachometer? Maybe an hour meter that also reads RPMs. You should verify that your operating rpm is infact 3500-3600 rpm.
My 928 now with about 8 hours on it has improved power over brand new. As the rings wear into the cylinder, friction drops and compression rises making a bit more power.
But still your machine shouldn't be struggling with 5" at its slowest forward speed. I've gone through 20" of saturated EOD snow, at faster then crawling speed.
Honda HSS928atd
MTD Gold 826
MTD 5.5 21"
Toro Powerlite
drmerdp is online now
post #3 of 7 Old 02-15-2017, 02:49 AM Thread Starter
I put an hour/tach/volt meter on it the first day I got it. Should come w/ one from the factory. Anyway: yes, it's dead nuts at 3650 RPM at no load. I find under normal load it will drop to to 3300-3400 - still sounds healthy here. However, once I start to creep the speed up the RPMs drop like a rock.
keeena is offline
post #4 of 7 Old 02-15-2017, 06:35 AM
Thanks (Given): 24
Likes (Given): 55
Likes (Received): 20
Originally Posted by keeena View Post
Hi all, I have a new HSS928AWD, my first Honda snowblower.
Welcome to the forum, Keeena. Sorry you're having trouble with the new machine.
First, drmerdp gave good advice. Plus, what I would do before much of anything else is watch a few videos about the HSS928 and compare. One in particular is posted below. If your machine isn't behaving like that, then I'd be fast to the dealer who sold it to me while there is snow on the ground for them to experience the problem firsthand.
Another good resource on here is Robert@Honda. He won't tell you how to fix it, of course, but might be able to send additional recommendations your way.
Good luck. Here's the video:
Tom
2016 Honda HSS1332ATD = "Virginia Virgin"
Tomatillo is offline
post #5 of 7 Old 02-17-2017, 01:50 PM
I have the exact same problem Keena. HSS928 ATD. As soon as I feed the machine into snow a bit too quickly I can almost stall it. sounds like 200 RPM. Please let me know if you find a solution to this problem.
Icicleboy is offline
post #6 of 7 Old 02-17-2017, 02:19 PM
Likes (Given): 7
Just a thought...Is it possible that the engine is working just fine, and the machine cannot deliver on how fast you think it should be able to go?
The HSS928s are not powerhouses. Especially with the larger impeller compared to the HS generation. You can choke it.
Once the Warrenty is up on my HSS928 I'm going to take a good hard look at installing a gx390. That being said, I'm not upset that my 928 isn't more powerful. But I am a sucker for modifying and improving things.
Some machines will plow a pile infront of the bucket Bog substantially but not stall, My MTD is an example of this. Where as others will bog down until they stall.
Honda HSS928atd
MTD Gold 826
MTD 5.5 21"
Toro Powerlite
post #7 of 7 Old 02-17-2017, 03:08 PM
jrom's Avatar
Thanks (Given): 128
Thanks (Received): 49
Likes (Given): 366
Likes (Received): 64
Originally Posted by drmerdp View Post
...Once the Warrenty is up on my HSS928 I'm going to take a good hard look at installing a gx390.
I can say you will love the extra power. It's the only reason I bought a 1332. After 25 years of an aging on-edge underpowered GX240, it pushed me that way. I knew one extra hp wouldn't cut it for my location.
1991 Honda HS828TAS (tracked) - 1st gen hydrostatic Oct 1991
2016 Honda HSS1332ATD (tracked) - 1st gen US assembled two-stage Nov 2015
jrom is offline
Human Verification
