HS 928 How long is your auger belt lasting? - Snowblower Forum : Snow Blower Forums
 4Likes
post #1 of 27 Old 02-15-2017, 06:09 PM Thread Starter
Prime's Avatar
Likes (Given): 47
Likes (Received): 16
I purchased a used HS 928 last fall. It was in great shape had not seen alot of use. Went over the machine complete. Put both belts new at that time. I put an hour meter on so I know how long parts last. Last week we had a really heavy snow 12 in with rain. very heavy stuff. Did about 10 driveways. Blower handled it fairly good with small cuts. All things considered definitely hard on the blower. Before the day was done my auger belt was slipping and would no longer pump snow at all. Actually it just stopped blowing mid cut no sign of slippage. I dont understand it unless I got a splash of water on the belt to start the slip. I took it to the shop for repair still wouldnt pump. Fired on a new belt were all good again. The belt did not look bad, no cracks ,breaks or burns and no smelling rubber at any point, and had run only 21 hours total. Would this be normal under this type snow? Ive never had one just suddenly quit, usually I see a weak spot etc. during maintenance and just change it out just to prevent a problem. What kind of belt life do you get?
commercial snow blowing
HS 928 - 2008
HSS 928 (2015 Canadian version)
Prime is online now
post #2 of 27 Old 02-15-2017, 06:43 PM
DriverRider's Avatar
Likes (Received): 8
OEM belts? It probably just needed a tensioner adjustment and all would have been well for the remaining life of the belt.
2015 Simplicity P1728e 420cc modified for 21.00TP
1963 Snowbird S263
1962 Snowbird S225
DriverRider is online now
post #3 of 27 Old 02-15-2017, 07:29 PM
94EG8's Avatar
Thanks (Received): 46
Likes (Received): 42
OEM belt? If not that's more than likely you're problem. If not check the arms the idlers are on, see of the plastic bushings they pivot on are worn.
94EG8 is offline
post #4 of 27 Old 02-15-2017, 07:41 PM
tinter's Avatar
Thanks (Received): 25
Likes (Given): 81
Likes (Received): 36
I just replaced a belt in my buddies 25 year old machine, it's a 828 and it was the original part.
tinter is offline
post #5 of 27 Old 02-15-2017, 07:42 PM
Thanks (Received): 23
Likes (Given): 7
Likes (Received): 51
I agree that adjusting the belt tension might have been all that was needed.
It's totally possible for an aftermarket belt to have been manufactured just slightly longer then an oem and now it's not being tensioned properly.
It's also possible for any belt to stretch a bit in it life time.
Typically with the Kevlar coated belts the coating will be torn or super smooth when it's time for replacement.
drmerdp is online now
post #6 of 27 Old 02-15-2017, 07:47 PM
15 Years
I have a 2002 928. We live in a snow belt in NW Michigan and this blower has run great and blown snow for 50 ft for hundreds of hours.
I will have the belts checked when it goes in for service after the season is over.
Guess I'm just lucky?
Natty Bumpo is offline
post #7 of 27 Old 02-16-2017, 02:15 AM Thread Starter
Prime's Avatar
Likes (Given): 47
Belt is an OEM Honda belt. Tensioner was at the limit. I may have to look deeper for the cause of the failure. Too much play somewhere bearing etc.
HS 928 - 2008
Prime is online now
post #8 of 27 Old 02-16-2017, 02:24 AM Thread Starter
Prime's Avatar
Likes (Given): 47
25 years ,....... Amazing. I have never got more than a couple seasons max out of any blowers I have owned. Run MTD s for 20 years. Belts were a regular thing with them.
tinter likes this.
HS 928 - 2008
Prime is online now
post #9 of 27 Old 02-16-2017, 07:36 AM
Thanks (Given): 90
Thanks (Received): 223
Likes (Given): 288
Likes (Received): 329
Is it the belt? Or perhaps the impeller shear pin broke making the pulley spin but not the impeller or augers? This would be my bet if the belt condition and tension are good.
Take the belt cover off and, and inspect what is happening there, if the impeller pulley spins normally when the clutch is engaged, then the pin would be your issue.
Another thing to look at would be the auger clutch cable/arm spring (but if something is wrong here the lever at the handle bar would feel abnormal.
YSHSfan is online now
post #10 of 27 Old 02-16-2017, 09:57 AM
orangputeh's Avatar
Thanks (Given): 85
Likes (Given): 38
Likes (Received): 30
In my experience I have seen Honda belts last 20 years and more. The tension has to be right .
also make sure it is running in the center of the pulley. I threw a belt a couple times before I learned that lesson.
The machine was over 30 years old and the bushings were all worn out on the pulley assembly . 4 of them. what a job replacing them but now the belts run dead center on the pulleys.
i still haven't figured out how to properly tension an auger belt. i measure the handle to be about 4.5 inches ( i think that is what it is ) when the belt starts to move. that is in the factory manual for an 828.
what goes around comes around
orangputeh is online now
Human Verification
