Honda HS 50 Control Panel and Other - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 05-19-2017, 12:07 PM Thread Starter
orangputeh's Avatar
Thanks (Given): 87
Thanks (Received): 7
Likes (Given): 38
Likes (Received): 39
Recently picked up HS50 pretty cheap but had a carb issue.
He( previous owner) tried taking it off and just cut fuel line and broke the plastic part for the choke arm.
Well, no problem , I have a carb from a donor machine.
How do you get the control panel off? I took the gas tank off. the 2 top bolts off. for the life of me how do you get that bottom bolt off? it seems totally unaccessible.
I needed to replace the fuel line. so i took the gas turnoff knob out. there are 2 little screws holding the 2 fuel lines on the metal turnoff/on switch. One was easy. No way to get to other.
I drilled a hole in control panel just so i would have a clear shot to that other screw. removed switch and replaced fuel line.
even if i got whole control panel off I can not see how you can remove that fuel switch unless you had a elbow ratchet screw driver. don't even know if they make those.
well, anyway. should have came here to ask before doing this. once i start something I can't stop because I will forget how to put things back together after a day or so.
what goes around comes around
orangputeh is online now
post #2 of 3 Old 05-19-2017, 12:11 PM
Thanks (Given): 90
Thanks (Received): 228
Likes (Given): 295
Likes (Received): 335
If you tend to forget how things go back together, take pictures as you take stuff apart, this way you can always look at "how it was before".
YSHSfan is online now
post #3 of 3 Old 05-19-2017, 04:10 PM
robert@honda's Avatar
Thanks (Received): 215
Likes (Given): 36
Likes (Received): 216
The shop manual is pretty light...but these pages might help:
Robert@Honda
Social Media Consigliere
robert@honda is online now
Likes YSHSfan liked this post
Human Verification
