Good Deal or Not - Snowblower Forum : Snow Blower Forums
 1Likes
  • 1 Post By JD in NJ
post #1 of 9 Old 10-27-2016, 09:09 PM Thread Starter
Good Deal or Not
Time will tell. Hello new to the forum. Just bought a Simplicity 860 with Tecumsh engine at a garage sale for $200. All I can say for it is that it runs. Spent all day on it today. Cleaned out the mouse house in the lower bay- yuck!
Put in the right spark plug -J19.
Changed the oil
Recycle the gear oil
Greased the chain wheel
Replaced the dive belts
Lubed the chute
Replaced all the hardware on the scraper and skids
Removed rust and repainted here and there
Probably need to check the carb. It runs a little nervous. Got good info on the blower but I could use a
Good engine repair manual. Im a rookie at small engine repair. Time will tell if I got my moneys worth.
filthyfingers is offline
post #2 of 9 Old 10-27-2016, 10:01 PM
Thanks (Given): 66
Thanks (Received): 191
Likes (Given): 124
Likes (Received): 526
Hard to say without seeing it. I don't think $200 is crazy but I really can't say w/o pics.
Toro 5/21
Ariens Sno Tek 7/24
Old green plastic snow shovel
post #3 of 9 Old 10-27-2016, 11:09 PM
Thanks (Given): 89
Thanks (Received): 111
Likes (Given): 525
Likes (Received): 167
Changed the oil
Lubed the chute
Welcome filthy! That's a bombproof blower!
Here's the Tecumseh L-head service manual.
...and if you find yourself stuck even with the Tecumseh bible in-hand, youtube can be a tremendous resource. Donyboy73 has a pretty good channel.
post #4 of 9 Old 10-28-2016, 04:27 PM
Thanks (Received): 82
Likes (Given): 126
Likes (Received): 260
Agreed lots of great vids to walk you through most anything. Be sure to check the the augers are free and not frozen to the shaft also.....and grease them too! ensure it has correct shear bolts in there and not hardware store bolts.... should make for a nice machine!
post #5 of 9 Old 10-29-2016, 09:32 AM Thread Starter
Thanks for the advice. Especially the service manual. I'll inspect the augers for sure. Now to figure out attachments...
post #6 of 9 Old 01-11-2017, 08:25 AM Thread Starter
Thanks again. Not much snow so far but enough to say this snowblower is a beast. New hardware on the skids and minor adjustment has this machine blowing the driveway clean.
Now if I could only find the air filter. I swear it doesn't exist.
post #7 of 9 Old 01-11-2017, 08:31 AM
JD in NJ's Avatar
Likes (Given): 30
Likes (Received): 10
That's because it doesn't. You won't find air filters on snowblowers as a general rule.
filthyfingers likes this.
JD in NJ is online now
post #8 of 9 Old 01-11-2017, 09:37 AM
Likes (Given): 126
Yep, they need all the air they can get when it's cold out. The air box helps to warm the air up and also to prevent snow from getting sucked in. If it has been repowered at some point - it's possible that soembody used an engine from a tiller or something that would have had a filter.......
post #9 of 9 Old 01-12-2017, 04:07 PM Thread Starter
Human Verification
