simplicity 755 snow blower - Snowblower Forum : Snow Blower Forums
Register Home Forum Active Topics Gallery Search Today's Posts Mark Forums Read Snowmobile Escrow
Old 03-29-2012, 02:02 PM   #1
Default simplicity 755 snow blower
I just picked up a used simplicity 755 snow blower cheap. It is in non running condition. The electric starter is trashed and the recoil starter was with the engine but not mounted. The engine turns free and appears to have good compression. The rest of the machine is in very good shape and it is not a friction drive model it has a gear box with 3 forward and one reverse speed.
The engine is a tech H70 130261l 7 hp engine. The drive dog and spring are missing from the recoil starter does anyone know what the part numbers for these items are?
Carl
CarlB is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 03-29-2012, 03:24 PM   #2
Default
I found this link for the engine:
Parts and Diagrams for Tecumseh H70-130261L
And this one is shown as the starter:
Parts and Diagrams for Tecumseh RS1-590473
Shryp is online now
Old 03-29-2012, 04:59 PM   #3
Default
Thanks Shryp, I see you get around to the same sites that I do.
I was a little surprised to see a 7hp engine on a 22" wide machine.
CarlB is offline
Old 04-03-2012, 08:29 AM   #4
Default Dog and spring
There are more than one style dog and spring in the recoils so make sure what you're looking for. On some, the end of the dog has a circular end that fits in a slot in the recoil and I've seen that slot (typically plastic) where it's been broken DAMHIK. If that's the setup you have, there's also a small tab and screw that holds the dog into the recoil assembly.
I've also swapped recoils between 4, 5 & 7 hp motors before. Only issue may be the alignment of the mounting holes. Some are rotated 45 degrees compared to others, but they still work.
HCBPH is offline
Old 04-07-2012, 07:10 AM   #5
Default
The recoil starter that i have only has one dog and it does have the plastic slot with the small tab and screw to secure it. it does appear to be in good shape except the the dog and spring are missing. I ordered what I believe to be the correct spring and dog and will give it a try when it gets here.
Thanks for your help
carl
CarlB is offline
You may not post new threads
You may not post replies
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Compact Tractor Reviews Tractor Reviews Snowblowers Lawn Mower Forum
My Tractor Forum Snow Thrower Power Equipment Forum
Combine Forum Snowblower Forum ATV and UTV Reviews
