Yard Man 8/26 slow and variable in forward speeds - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 01-10-2017, 01:50 PM Thread Starter
I have a Yard Man 8hp 26" blower from 1977, and it has been gradually losing forward speed over the past 3 years.
The symptom is inconsistent forward speed when I change in and out of a specific gear. So if I am in second and shift into reverse to reposition, going back into second usually has a different ground speed. This is most obvious in 5th, which is usually a brisk walk: this past weekend it was a normal pace. There is also "slip" of some sort, meaning going up a slope I lose forward speed. This blower used to be UNSTOPPABLE in first, so grippy it would drag me no matter how much resistance I put on it.
I changed the drive belt this past fall with a factory part. I changed the friction wheel about a year before that, cleaning the friction disk with brake cleaner (none touched the rubber wheel), and the disk was in great shape. This really leaves just couple things remaining: friction disk, play in the friction wheel positioner, friction plate to disk pressure, drive belt sheave on the engine crank shaft, idler belt tensioner.
Other things to check?
thool is offline
post #2 of 9 Old 01-10-2017, 01:55 PM
I had some corrosion on the device that lifts the disc to the friction wheel. PB blaster and time to soak fixed it for me. I did clean the disc with acetone also.
Deere Owner is online now
post #3 of 9 Old 01-10-2017, 02:34 PM
How about cable adjustment?
The Q is offline
post #4 of 9 Old 01-10-2017, 04:24 PM
Likes (Received): 42
The chain gear may have sheared its pin and be intermittently turning on its shaft. Not a common problem, but it does happen. If you scribe the gear and the shaft, it' s easy to rule out slippage. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #5 of 9 Old 01-10-2017, 04:58 PM
Thanks (Given): 392
Thanks (Received): 453
Likes (Given): 2523
Likes (Received): 857
Sounds like you might need to clean up and lightly lube the shaft the friction disc slides on.
Here are some how to videos: https://www.google.com/#q=donyboy+++...tion+disc+lube
If it's not that I'd check the shifting rod(s) to see if something is loose in the linkage and not replicating the position consistently.
post #6 of 9 Old 01-10-2017, 09:52 PM
Thanks (Received): 8
Likes (Received): 28
For sure I'd look for looseness in the friction wheel horizontal position. Open up the transmission and try moving it side to side with your hand while the speed selection lever is engaged into a speed position.
guyl is online now
post #7 of 9 Old 01-11-2017, 01:27 AM
Thanks (Received): 22
Likes (Given): 7
Likes (Received): 40
It's anyone's guess until you open up the cover and give it a good look, but I'd suspect the linkages that slide the friction disk into the selected position. By now I'd assume the eyelets and rods would have substantial play in them.
Honda HSS928atd
MTD Gold 826
MTD 5.5 21"
Toro Powerlite
drmerdp is online now
post #8 of 9 Old 01-11-2017, 03:49 AM
Likes (Received): 6
A loose handlebar assembly can cause this. Since the cables are attached to it, when you vary pressure on the handlebar, you also vary tension of the rubber drive disk to the drive plate. very common...
Marty
majorxlr8n is offline
post #9 of 9 Old 01-11-2017, 08:21 AM Thread Starter
So I suspect play in the linkage that positions the friction disk, as well as the one that pushes the friction disk and friction wheel. There seemed to be plenty of contact when I looked in there, but maybe the play is more pronounced under load. Thanks for all the tips so far, I'll take this apart this summer and make a project out of it.
thool is offline
Human Verification
