Do you use fuel cleaners, when needed or every time? - Snowblower Forum : Snow Blower Forums
View Poll Results: Do you use a fuel cleaner, never, regularly, occasionally?
I never use a fuel cleaner 7 17.07%
I regularly use a fuel cleaner by putting it in my gas can on every fuel up 21 51.22%
I occasionally use a fuel cleaner when I think about it adding it to the blower 9 21.95%
I only use a fuel carb cleaner when I have a carburetor problem 4 9.76%
Voters: 41. You may not vote on this poll
post #1 of 52 Old 02-15-2017, 10:14 AM Thread Starter
Thanks (Given): 14
Thanks (Received): 20
Likes (Received): 38
It seems sooner or later we all are going to have a carburetor problem, hard starting, surging, rough running, no power, no power under load, stalling, poor idling, whatever.
It can be reduced by using fresh fuel, turning the fuel over often, using fuel stabilizers, StaBil, Seafoam, and by draining the gas tank and carburetor either after each snow or at the end of the season. You can also use a shut off valve on the gas tank, turn it to off, and drain the carburetor only.
And many do nothing! Then solve the problem by using a fuel carb cleaner, rebuilding, or replacing the carb.
Do you use a fuel cleaner at all, only occasionally, only when you have a problem, or regularly?
What do you use?
post #2 of 52 Old 02-15-2017, 10:26 AM
Thanks (Given): 399
Thanks (Received): 190
Likes (Given): 233
Likes (Received): 486
I have never used any of that stuff here in the frozen tundra. I fill the tankers just when the weather monkey's are crying we got a storm coming our way. never turns out the way they played it up. so I fill the engine tank when I am going to use it. and when it is all said and done then I reach under there and turn the valve off so the engine starves itself of fuel. put it back in the garage.and do it all over when duty calls once again. what I don't use in the winter I just run in the mower in the summer. and when the tanker is empty. I hoof it up to the holiday on the corner fill it up. and everything begins again. and have never had any problems doing it my way. I still have yet to try the higher octane issue I ranted on in another thread somewhere around here.
post #3 of 52 Old 02-15-2017, 10:34 AM
Likes (Received): 6
On all my equipment, I don't deal with the carbs. unless there's a need. I do use StaBil and Sea Foam in the gas regularly as a stabilizer (not carb. related) plus an extra ounce of Sea Foam early in the season.
Tony P. is offline
post #4 of 52 Old 02-15-2017, 10:43 AM
I use a double-dose of Stabil every time I fill up the gas can.
I get lazy and will often leave the tank partially full in the offseason. I didn't use my snowblower at all last year so when I went to start it up a week ago, it still had fuel from the end of the 2015 season. The engine started up fine and I ran through the rest of the tank during the storm on almost 2 year old fuel.
I will keep on using a double-dose of Stabil every time I fill up the gas can.
BeansBaxter is offline
post #5 of 52 Old 02-15-2017, 11:09 AM Thread Starter
Thanks (Given): 14
Powershift, I have to laugh at your post as that's what I do. After I use it, turn the shut off valve off and run it dry choking it. I do use Stabil as I like fresh gas. If I don't have any gas, I don't get it until the day of or the day before the snow falls vigilantly checking the Doppler. Then I don't put any in until I use the machine, snow snow snow and we get nothing. I know all my machines will start and if not, with ether. At the end of the season if it's pushing 60 days it goes in my car.
post #6 of 52 Old 02-15-2017, 11:11 AM
Thanks (Received): 7
Likes (Received): 16
I use a little Seafoam and Marvel Mystery Oil in my gas, and I use 93 octane in the blower and mowers, only because I feel like the effects of ethanol is lessened by the higher octane. I could be wasting a little money but I feel better about it. At the end of the season I siphon out the tank, run it out of fuel and drain whatever is in the bowl. Then I hit the inside of the tank with fogging oil. I feel that's better than leaving stabilized fuel in it for 8 or 9 months.
dhazelton is offline
post #7 of 52 Old 02-15-2017, 11:16 AM
Snowbelt_subie's Avatar
Likes (Received): 9
never used anything before this year figured i would try some seafoam in the gas of my 2 and 4 stroke small engines.
i had a tecumseh engine i did a carb clean on and still had a surging problem. after running a seafoam heavy mix for a while it cleared up.
it cant hurt as a fuel additive/ stabilizer so why not run it?
Current Toys
John Deere SXT38 12.5hp kohler
Toro CCR 3650 6.5 hp B&S
Toro CCR 2000 47p Suzuki #38185
Honda HS621 GX160
Honda HS521 GX140
Toro CCR 2400 hsk- 850
Toro power clear 180 87 cc 4 cycle engine
Snowbelt_subie is offline
post #8 of 52 Old 02-15-2017, 11:17 AM
Thanks (Given): 399
Likes (Given): 233
Well I am just glad that someone reads them.
post #9 of 52 Old 02-15-2017, 11:32 AM Thread Starter
Thanks (Given): 14
I use fuel stabilizer because it can't hurt and it's the right thing to do. I use a fuel carb cleaner in my gas can because it can't hurt.
post #10 of 52 Old 02-15-2017, 11:33 AM
Any information on this? I've heard a theory that higher octane in 2-stroke engines helps with cooling (not sure it's true) but never any details about ethanol. Interestingly, my chainsaw requires minimum 89 octane but all the 4-stroke OPE engines I've seen only require 87 octane.
FWIW, higher octane fuel is still going to have ethanol unless it's specifically labeled ethanol-free.
For 4-stroke engines the compression ratio is low enough that higher octane really shouldn't make a difference.
Human Verification
