Tecumseh RPM Range - What's Normal? - Snowblower Forum : Snow Blower Forums
post #1 of 20 Old 03-13-2017, 06:50 PM Thread Starter
I just tried out my new Briggs + Stratton vibration tachometer, and it's great!
Used it on a '94 Tecumseh flathead Snowking engine. Here's what I got.
Idle 2,200 rpm
High 3,900 rpm
How are those numbers? Does my machine need adjustment?
Here's a pic of the sirometer (vibration tachometer)
Sign216 is offline
post #2 of 20 Old 03-13-2017, 06:57 PM
Thanks (Received): 15
Likes (Received): 24
If that's accurate you may want to slow it down, Tecumseh has a great engine but they don't like much above 3600, There known to break the piston shaft and ventilate the case when it happens.
Craftsman 3.8hp Tecumseh single stage
Snapper 6/22 my little workhorse
Ariens ST1027LE new workhorse
Dauntae is online now
Thanks Sign216 thanked for this post
post #3 of 20 Old 03-13-2017, 06:57 PM
Thanks (Given): 111
Thanks (Received): 123
Likes (Given): 682
Likes (Received): 207
3900 is way too high. a tecumseh should never exceed 3600. That idle is about right.
This happens when tecs run low on oil &/or are over-revved (broken connecting rod):
('95 Ariens ST724)
post #4 of 20 Old 03-13-2017, 07:17 PM
Thanks (Given): 20
Thanks (Received): 57
Likes (Given): 50
Likes (Received): 122
I dunno, I think some Seafoam ought to fix up that blown connecting rod
Yeah, take it down to 3600, or whatever the manual says. The manual may also have a suggested idle RPM. I believe the idle speed is selected to keep it from stalling, but also to provide enough circulation of the oil.
How is the vibratach to use? I was thinking about getting one, but ended up buying a tachometer/hour meter instead.
Toro Powercurve 1800
RedOctobyr is offline
post #5 of 20 Old 03-13-2017, 07:51 PM Thread Starter
3,900 is too high? Ok, good to know.
Idle of 2,200 sounded high to me. But if you guys say that's normal, then I'm ok with it.
A working range of 2,200 to 3,600 isn't much.
The vibratach is used by holding the unit firmly against the machine, and then turning the dial. Turning the dial feeds the wire in/out, and when the engine vibration matches the harmonic frequency of the wire length, the end of the wire vibrates at it's maximum. You then read the dial.
It sounds hard, but in actual use it's amazingly simple and easy.
I thought about mounting magnets to the bottom of the unit, to free one hand, but I think the engine shakes too hard for this.
Sign216 is offline
post #6 of 20 Old 03-13-2017, 07:56 PM
Thanks (Given): 16
Likes (Given): 9
Likes (Received): 8
I recently bought one of those vibratachs. Really, really cool tool. Surprisingly easy to use
My machine:
Stang is offline
post #7 of 20 Old 03-13-2017, 07:59 PM Thread Starter
Hey, the vibratech (and this forum) stopped me from over-revving my engine.
Sign216 is offline
post #8 of 20 Old 03-13-2017, 09:16 PM
Thanks (Given): 14
Thanks (Received): 20
Likes (Received): 38
I was shown the VibraTach by a John Deere dealer in 1979. He loved it and used it all the time.
I'd like to see someone compare that using a light tach to see how accurate it is. If it's off 100 rpms at 3,600 that could be a devastating difference to a Tecumseh engine.
Noma 9hp, 27"
Several other 5hp, 8hp, several 2 cycle, electric snow shovel, all for sale
post #9 of 20 Old 03-13-2017, 09:40 PM
not saying the sirometer is inaccurate..but you cold just use a digital single wire tach that wraps around a spark plug lead. simple to use permanently or just temporary for testing. they are about 12 dollars from many places including ebay..
97 husqvarna st521 w/ tecumseh hsk850 149cc 2 stroke
17 ariens path-pro ss21ec w/ lct 208cc 4 stroke
justintendo is offline
post #10 of 20 Old 03-13-2017, 10:03 PM
1132le's Avatar
Idle 2,200 rpm
High 3,900 rpm
How long have you been runnng it @ 3900 ? years?
if so maybe they throw rods from bad maintenance/ low oil not being run above 3600 +/- 150
1132le is offline
Human Verification
