Which Sta-Bil product to use? - Snowblower Forum : Snow Blower Forums
 3Likes
post #1 of 23 Old 03-30-2017, 08:28 PM Thread Starter
Thanks (Given): 14
Thanks (Received): 19
Likes (Received): 38
I went to the Sta-Bil website to read about their products and I learned they have a lot of different but similar products. So which one to use? the stabilizer, fuel cleaner, their additive product when using ethanol gas, they have several products which emit a vapor to prevent the gas tank from rusting. The latter was mentioned on SBF recently.
I sent them this email below and received the reply below that.
Submitted on Wednesday, March 29, 2017 - 13:11
Which product should I be using to stabilize my gas in my lawn mowers and snowblowers in the off season and in between snows. the gasoline in my area has 10% ethanol. I'm more interested in fuel stabilization than a fuel cleaner as I do use fuel carb cleaners. I don't know if the 10% ethanol is important to my situation for your recommendation.
Their reply
Hello John,
Thank you for contacting Gold Eagle (Sta-Bil). For storing and protecting your equipment, and use during seasonal use we definitely recommend treating your fuel with STA-BIL 360® Performance™. It is specially efficient in ethanol blended fuels to protect against corrosion, rust and water issues. It will keep fuel fresh up to 12 months. Hope this helps. Please let us know if you have any questions.
Best regards,
Conrad
Several other 5hp, 8hp, several 2 cycle, electric snow shovel, all for sale
post #2 of 23 Old 03-30-2017, 10:30 PM
Spectrum's Avatar
Thanks (Received): 30
Likes (Received): 91
It may keep your fuel fresh but don't count on the carburetor being safe. Dry off season storage has been much more predicable. I think the 360 line is new but their prior Ethanol products didn't serve me well through the off season. I'm in no hurry to revisit the November surprise.
Spectrum is online now
post #3 of 23 Old 03-30-2017, 11:08 PM
Thanks (Given): 67
Thanks (Received): 199
Likes (Given): 130
Likes (Received): 552
None. Startron and seafoam blend.
Saewoody and 43128 like this.
Toro 5/21
Ariens Sno Tek 7/24
Old green plastic snow shovel
post #4 of 23 Old 03-30-2017, 11:25 PM
Thanks (Given): 27
Thanks (Received): 79
Likes (Given): 412
Likes (Received): 108
use startron, stabil is junk. if you have a medal tank add 2 capfulls of two stroke oil for rust prevention
Saewoody likes this.
post #5 of 23 Old 03-31-2017, 12:49 AM
GoBlowSnow's Avatar
Thanks (Received): 46
Likes (Given): 47
Likes (Received): 117
I have used the 360 the past 2 years since it was released to the market and not one problem with the snowblowers I have used it on. I do fire these engines up once every 2 months or so during the spring and summer.
GoBlowSnow is offline
post #6 of 23 Old 03-31-2017, 07:24 AM
Thanks (Given): 60
Thanks (Received): 63
Likes (Received): 98
Yeah, I've had good luck with the Stabil products over the years. I think the "360" product is what I have now. I've also had good luck with the others mentioned.
I'm running my machines dry and re-filling with 1/2 qt of the synthetic gasoline before putting things away for the season. That product is supposed to be good for 2 years and doesn't need any further additization.
2014 Ariens 28" 921036 | poly skids | heated grips
2015 Ariens 24" SHO 921038 | ARMORskids
uberT is online now
post #7 of 23 Old 03-31-2017, 08:18 AM
Thanks (Given): 13
Likes (Given): 20
Likes (Received): 31
I'm not much of a fuel connoisseur, but use the red Sta-bil once in a while. I use some 2-cycle oil in the fuel to fog the engine for off-season layup and keep the tank from rusting. Then some carb cleaner in the fuel when the season starts up again.
Whatever additives you use or don't use, as long as you don't something like pee in the fuel tank, it should be fine.
I find that a heavy dose of carb cleaner at the start of the season is the most beneficial.
Regards, Ted
Current Fleet:
2017 Husqvarna ST224
tpenfield is offline
post #8 of 23 Old 03-31-2017, 09:01 AM Thread Starter
Thanks (Given): 14
Why 2 cycle oil? Why not an engine oil, multi viscosity, straight 30, or non detergent 30? Years ago prior to 2 cycle oil they use to use non detergent 30.
How do you fog your metal gas tank and with what?
post #9 of 23 Old 03-31-2017, 01:09 PM
Thanks (Given): 27
Likes (Given): 412
any two stroke oil. i buy the big gallon of supertech
post #10 of 23 Old 03-31-2017, 01:59 PM
Thanks (Received): 28
Likes (Received): 64
I use the Blue sta-Bil. I think it's called 360 marine. Either way, I added to everything year round.
Last year I stored my Honda with a full tank of fresh, treated, non ethanol gas and the bowl empty.
This year I forgot ask my snowmobiling buddy to bring me back any non ethanol gas so... I'm storing totally dry this season.
I also fog my machines with CRC engine stor.
Honda HSS1328AATD
MTD Gold 826
Simplicity 520
Toro Powerlite
drmerdp is offline
Human Verification
