John Deere TRS 32 problems - Snowblower Forum : Snow Blower Forums
post #1 of 20 Old 11-29-2012, 08:48 PM Thread Starter
Hello all, I have some questions regarding my snowblower.
First thing: I got the snowblower for and, and we happened into some really heavy wet snow. I burned the auger belt out, and replaced it. After that, it would not aug for more than 10 seconds.
Second, is i think the primer bulb blew. It seems to leak more gas than it uses. I cant seem to find a hole in the line, but it goes through/around the block where the primer is. Can i bypass that and just use starting fluid?
I cant seem to find any free manuals online, and was wondering if you guys could help me out at all.
thanks!
colsanders is offline
post #2 of 20 Old 11-29-2012, 11:19 PM
Simplicity Solid 22's Avatar
Hopefully someone will come through for you otherwise Ebay is best bet. If not john Deere tech Manual $65 via CD. Try these links below...
manuals john deere trs 32 | eBay
https://techpubs.deere.com/products/ProductResults.aspx
post #3 of 20 Old 11-30-2012, 05:17 AM
Thanks (Received): 50
Likes (Received): 96
John Deere
First off - Welcome to the forum
Your primer issue is strange. All a primer bulb does is pressurize the carb to push a little gas into the throat so id you're having gas come out of the bulb then something strange is going on.
As far as your belt issue, there's a number of possibilities. The pulleys or belt could be glazed over. The idler could be misadjusted. The impeller bushing could be bad. The pulleys could be out of alignment. Something could be catching or jamming somewhere. Sorry, but there's not enough info to help narrow it down.
HCBPH is offline
post #4 of 20 Old 11-30-2012, 08:37 AM
Thanks (Received): 222
Likes (Received): 596
Unfortunately you won't find a free manual online. I just went through the same sort of thing for a John Deere Lawn mower I recently bought. Finally had to break down and buy one.
You can get them directly from John Deere if you wish.
John*Deere Products & Services
You can easily get the parts diagrams from at least a couple of different places.
John Deere - Parts Catalog
John Deere TRS32 Parts List and Diagram : eReplacementParts.com
post #5 of 20 Old 11-30-2012, 09:08 AM
Thanks (Given): 35
Thanks (Received): 218
Likes (Given): 78
Likes (Received): 415
Just curious..did you mean to say " I got the snowblower for free"?
If so, I might have some specific advice for you, if that is the case.
post #6 of 20 Old 12-01-2012, 03:16 AM
jtclays's Avatar
Thanks (Received): 109
Likes (Given): 64
Likes (Received): 168
Cole, I think the TRS is actually an Ariens produced model for JD. Mr. Deere is very secretive about his walk behind snowblowers
Engine nomenclature would help (Tecumseh, Briggs, LCT???)
A picture could get some more response? Are you having trouble starting it now, or are you stuck in the belt area? If you are "burning" belts it may be as simple as a spring coming off the auger brake, or a seized auger idler pulley.
The primer should, and will, pump gas out of the carb if pushed a few too many times. Not bashing you, but if you're burning belts, the engine is running fine, correct?
post #7 of 20 Old 12-02-2012, 06:49 PM
trs deere are not ariens they were either murray or mtd, cheaply made sorry the truth hurts.
twofishy4u is offline
post #8 of 20 Old 12-05-2012, 09:12 AM
jtclays's Avatar
Likes (Given): 64
fishy, You are correct I think it's the "D" models (ie 826 D) that Ariens produced, not the TRS models
post #9 of 20 Old 12-05-2012, 10:50 AM
Thanks (Given): 169
Thanks (Received): 246
Likes (Given): 974
Likes (Received): 409
the motor is a 10hp tecumsch
2-toro 521E-38052
1-.............,TORO XL 624..............
1-............, TORO XL 824..............
post #10 of 20 Old 12-10-2012, 08:59 PM Thread Starter
Yes, it was free. My church gave it too me when they got a new one. The gas problem is coming from the petcock, and well as the fuel filter. What I thought might be a bad tensioner, appears to be a faulty pulley or bearing for the auger. It would spin for a couple minutes, and than seize up. Is there any good resources for parts you guys prefer?
Human Verification
