Ariens throwing distance - Page 5 - Snowblower Forum : Snow Blower Forums
Register Home Forum Active Topics Gallery Search Today's Posts Mark Forums Read Snowmobile Escrow
Old 02-28-2013, 10:40 PM   #41
Default
My 2.5" pulley from the same vendor was supposed to be delivered today via but according to the tracking number, it has been "missent." to the post office 2 towns over from me.
Hopefully they will sort it out.
db130 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 03-01-2013, 03:25 PM   #42
Default
After all the ideas I can think of, I'm down to two: A bearing seperator behind the pulley and use a puller to rip it off the shaft -or- a grinder with a cutting wheel to cut through the pulley and split it in half.
nt40lanman is offline
Old 03-01-2013, 05:49 PM   #43
Default
You don't have to cut through the pulley, I'd stop maybe 1-2mm short, then take a chisel or screwdriver right into the groove that you cut with the dremel.
db130 is offline
Old 03-02-2013, 03:01 PM   #44
Default
Update for today. I hit it with the grinder and split it off the crank in just a few minutes. I got it all together with a 1" longer belt and dove into the plowpath along the street. It's over a foot deep and soaking wet and the ariens chucked it 25+ feet. I could hear the engine slowing from the load. Then I ran it around back to some virgin (old) snow and it threw it almost 40 feet!!! Even with the engine at a low speed it threw further than it did before!!!!
It seems great. After a test in fresh snow I may back down the pulley if I think I need to. I jumped from 2.75 to 3.5 but may back off to 3.25.
Old 03-02-2013, 03:13 PM   #45
Default
Here's some pics. As you can see, it still doesn't throw ALL the snow the whole distance so I'd like to figure that out.
Old 03-02-2013, 07:00 PM   #46
69ariens's Avatar
Default
Seeing that the old snow is very wet, Id say it throws very good.
__________________
Scott
69 ariens
toro 2450
69ariens is offline
Old 03-06-2013, 11:59 PM   #47
Default
I have a homemade impeller kit on my Tecumseh, 10.5 hp, and it works great. It throws the snow at least 30 ft. Even wet snow.
sboricic is offline
Old 03-07-2013, 07:08 AM   #48
Default
I was thinking of an impeller kit or adding steel to the ends with a welder.
Old 03-07-2013, 07:34 AM   #49
Default
Where did u buy your belts? What size did u used with the 3.5" pulley? Why are you considering going with a 3.25 pulley?
MTD1014 is offline
Old 03-07-2013, 08:05 AM   #50
Default
I got the belts from Napa. I did a little interchange game with the original part number between various manufacturers. I calculated half the circumfrence of the two pulleys to arrive at a 1" longer belt and I checked it with the belt measuring tool at Napa. It's a 4L 1/2 belt, 37". The "gear ratio" with the new pulley is higher, putting more load on the engine. If after a few more storms I decide it's too much, I may back it down and give the engine a break but it'll probably be OK.
You may not post new threads
You may not post replies
Powered by vBadvanced CMPS v3.2.2
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Compact Tractor Reviews Tractor Reviews Snowblowers Lawn Mower Forum
My Tractor Forum Snow Thrower Power Equipment Forum
Combine Forum Snowblower Forum ATV and UTV Reviews
