2011 John Deere 1330SE Electrical Problems - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 02-09-2014, 09:01 AM Thread Starter
Looking for some good advice on troubleshooting my John Deere 1330SE snow blower. It has an electric chute control which is nice, but hardly ever works. It has a motor to angle the discharge which only worked the first couple weeks I bought it. The ability to rotate the chute itself only works infrequently, and sometimes not at all. Last time I used the blower, the right headlamp was out. I'm assuming there is an electrical problem somewhere. I bought the unit at Lowe's and they had me take it to a John Deere dealer, who was actually not helpful at all. (Most likely due to not buying it there). The blower is a beast at removing snow, and seems to get good reviews here and at other sites. It was bought in October 2011 and was used very little that first winter due to a mild season here in upstate NY that year. Because of that, I didn't realize the extent of the issue until the following year, well past any Lowe's warranty. Last year and this year it's getting more use. I'd be grateful if anyone had some tips for me; like to try to fix myself. Thanks!
tonymocciaro@yahoo.com is offline
post #2 of 16 Old 02-09-2014, 09:45 AM
Your going to have to isolate just where the prob is. When the chute direction is not working, try to probe the wires right before the motor to see if its getting power. Do the same for the angle control. If your not getting power at these places, check right before the power switch. This will tell you whether your having power, switch or motor problems.
cdestuck is offline
post #3 of 16 Old 02-09-2014, 11:28 AM
Likes (Received): 42
I couldnt find any wiring schematic on pdf file, just a parts breakdown. Where your problems appear to be affecting more than one circuit, they may be caused by moisture getting to your connectors.
Try disconnecting them one by one and spraying the contacts with WD40. Wipe them dry and see if you see any improvement. MH
motorhead64 is offline
post #4 of 16 Old 02-09-2014, 12:42 PM
69ariens's Avatar
Likes (Given): 52
Likes (Received): 62
First check you grounds.
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
post #5 of 16 Old 02-09-2014, 05:48 PM Thread Starter
Thank you for the tips; some more specific info I should have included earlier-the chute rotation usually does work for the first 5 or so minutes and then just quits. The motor that angles the discharge has not worked since perhaps the second time I used it, which was early 2012. When pressing the control switch for it to operate, the headlamp(s) dim greatly. Sometimes with repeated efforts it will operate again. I've checked the electrical connections for tightness, but I haven't sprayed them with WD40. There are a lot of wires that are connected with clips that seem like they could loosen. I would say in the 2.5 years I've owned the machine, it's been used 12-15 times at most. Thank you again for the advice and help!!!
post #6 of 16 Old 02-09-2014, 08:06 PM
Thanks (Received): 179
Likes (Received): 212
A dimming light would mean a high current draw. Perhaps something is frozen?
post #7 of 16 Old 02-09-2014, 09:47 PM
Thanks (Received): 140
Likes (Received): 277
I would concur on icing idea of the chute. I would make sure that there is enough lube to displace any moisture.
Or.
You could rotate the chute every few minutes, to break everything free.
post #8 of 16 Old 02-09-2014, 11:55 PM
Likes (Received): 7
Dimming lights when other appliance is in use? =Low voltage to the appliance. Voltage drop is tested by putting a volt meter lead as close to the appliance +12 and the + battery post. The reading you register is your voltage drop/loss. Anything over 2 volts requires help. Any of these reasons (heat) below would be a cause.
Wire size too small. Look for heat.
-install 10 gauge wiring.
Connections not passing current. Look for heat.
-double connection sizes amp rating
Battery voltage too low. Watch it with a volt meter while operating appliances.
-or Assist the battery with a battery charger looking for improvement.
Switch poor quality or size. Look for heat. Screwdriver across the poles at same time.
-upgrade to 30 amp switch
Shorted motor? Use an amp meter in line with that +12 volt supply to the motor. Anything over 6 amps doesn't sound like a healthy motor.
Mr Fixit is offline
post #9 of 16 Old 02-10-2014, 09:52 AM
Jay
Jay's Avatar
If the chute works fine when its thawed out/warm before blowing snow, then its most likely icing up and getting stuck. On mine I have to make sure the gear is greased every so often (monthly) by taking the black cover of the actuator off to access the rotating gear. Its important to keep ice from building up on the disc sprocket on the base of the chute that the actuator gear runs on. Spray some silicon lubricant on it helps. I sometimes use compressed air and a wand to blow all the ice and snow that builds up in that area when I am done working to keep this area dry. The actuator runs on AC power from the stator along with your hand grip warmers. The only thing that runs on DC is the headlamp which mine had a small inline rectifier on one of the red wires from the stator going to the light. It is normal for the light to dim when you press the button for the chute rotation. It also dims slightly depending on the level of heat you select for your hand grips. My light has burned out too, which I found out was due to too much vibration which reduced the life of the bulb in my case. I have since converted to LED lights and eliminated that issue. My 1130SE is pretty similar to yours if you have questions.
Current Machine:
2010 John Deere 1130SE
Heated grips
Electric chute
3-9W LED Light Upgrade
Armor skids
Other machines:
Red Handled Shovel
Orange Shovel
Wish List:
Simplicity P1738E 16.50 TP Briggs ES
Jay is offline
post #10 of 16 Old 02-14-2014, 07:25 PM
WestminsterFJR's Avatar
Today, the chute control stopped working on my JD 1330se as well. It would turn left, but not right. I removed the switch and separated the housing:
inside, there are 2 rocker/contact mechanisms. I removed them and bent them slightly.
Reassembled and tested. All is back in order.
-Ken
2011 John Deere 1330se
WestminsterFJR is offline
Thanks labman thanked for this post
Human Verification
