Won't blow snow - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 10-15-2010, 10:47 AM Thread Starter
Won't blow snow
I have a 2002 MTD Yardman snow blower I was using it last winter and got into some heavy going it almost powered out then it quit rotating or blowing snow. It is not the shear bolt that was the first thing I checked I put it away but now it is that time of the year when I will need it soon. Any help or ideas.
Excellent forum
TIA
pureel is offline
post #2 of 11 Old 10-15-2010, 04:20 PM
Have you checked all the belts? One of them might be broken or loose. I'm assuming the motor still starts but the auger just doesn't spin. What model is it?
amped_16 is offline
post #3 of 11 Old 10-16-2010, 11:02 AM Thread Starter
It starts and runs fine I will be getting it out of storage next week I will post back with the model number then. Where would I look for the belts on it this might be the problem. When you pull down the levers on the handles the one to make the blower part engage has almost no resistance to it so it could be a belt.
pureel is offline
post #4 of 11 Old 10-16-2010, 01:16 PM
I would check the belts.....also check the linkage that connects the handle lever to the pulley that tightens the belt to engage the impeller and augers. Something may have broken or come loose, or just needs to be adjusted. These machines are pretty simple, actually. Let us know what you find out!
Greg
gd9704 is offline
post #5 of 11 Old 10-18-2010, 01:27 PM
Just like gd9704 suggested I'd check linkage and make sure it is still physically connected to the pulley. It not too complicated and it should be very easy to spot the problem. Also if the linkage is fine check the belt while the motor is running. Play around with the lever and see if it actually tightens the belt enough or the belt just stays stationary.
gas_powered is offline
post #6 of 11 Old 10-20-2010, 12:29 AM Thread Starter
Got it out today took it a part and it was indeed a broke belt the one that drives the auger. Got out the owners manual found what I needed in it and got the new belt from NAPA and it is ready for snow. Thanks for all the help guys.
pureel is offline
post #7 of 11 Old 10-22-2010, 05:28 PM
I had a good feeling it was one of the belts. Glad we were able to help out. How much did the new belt end up costing you?
amped_16 is offline
post #8 of 11 Old 11-12-2010, 02:15 AM
You might want to be careful about belts bought from auto parts stores: You usually should get a belt marked for outdoor equipment or agricultural equipment and intended for clutching applications. These belts are made with Kevlar and are more durable, grip better, and are more flexible to meet the needs of being engaged and disengaged during use.
Some auto parts stores have or can get them. Tractor Supply, Jack's Small Engines, and Grainger are some places that definitely have them.
jhorwitz is offline
post #9 of 11 Old 11-12-2010, 02:43 AM
Agree with jhorwitz...All belts are not created equally. A belt that is designed for use in this application will last much longer than an automotive belt.
dakota60 is offline
post #10 of 11 Old 11-19-2010, 01:37 PM Thread Starter
The belt cost $18.00 and on the card the belt was in, it said it was for yard and garden use. The parts guy said it will work in the application I wanted it for.
Had 9" of snow overnight and just finished blowing out the yard it worked fine but now have another problem. Will post a new thread on it.
pureel is offline
Human Verification
