The drive chain on a John Deere TRS32 has jumped off the sprocket a few times in the last couple of years. After twenty-some years, the drive sprocket is pretty well worn down. Looks like its due to be replaced. However, I have been unable to locate one. Went to my local neighborhood JD dealer only to find out that the sprocket is no longer available. Searched a few parts web sites, (Amazon and eBay included) and googled it with no luck. The part number is: AM122090. Anyone have this sprocket laying around their garage or know where I can find one as shown here:
Any help or suggestions would be muchly appreciated.
I think your machine was made by Murray. If so, things don't look good for a new sprocket. However, this link should include a list of all the machines that used this sprocket, so maybe you can find one on a carcass, somewhere. Good luck.
You might end up having to go to a go-kart / mini bike supply place and buy a new sprocket that is designed to be welded to an axle or bore. If you can weld it yourself it will probably be fairly cheap or else you might have to spend a little extra taking it somewhere to be welded.
I do have a new chain but neither this new chain nor the original have master-links.
Was able to order a #420 master-link from Amazon so I'll try grinding a link off each chain and get the new, (unworn) chain on the sprockets.
We'll put it back together with a new chain and hope for the best. Hopefully, I can stretch a few more winters out of it.
That idea is in my mind. We'll see how the new chain works out when I get it installed.
I've kept this machine in tip-top shape since day one. Touched up the paint, new belts every so many years, new idler pulleys, changed oil every year even if it wasn't used much. These are factors I'll have to consider.
A buddy of mine has had one needing a chain. The old one is just gone. His serial # shows he needs the same part # AM122091 but he doesn't have the old one and doesn't want to pay JD prices for it either.
I can make him one . Next time he's in town and we are swapping stories I can send it with him.
Anyone ?
Related Threads
Snowblower Forum
461K posts
34.6K members
Since 2010
