Axel
If you look at page 30 of the schematic, it looks to me like you have a 3 piece axel in there! Without actually seeing it, this is pure guessing on my part based on the drawing only.
All this is based on the schematic on page 30 of the pdf you listed.
Now here's a suggestion - take pictures (alot of them) before you start and as you take things apart. It can be a life saver when it comes time to reassemble. If you can't keep parts alighned as they come out, bag and tag them so when it comes time to reassemble you can find all the parts and know where they go.
If it's one of the axel ends, I'm not even sure you have to remove the chains. Assuming you are trying to replace one of the actual axels a wheel bolts onto: looks like if you drive out the roll pin (#14), the axel will slide out. Just be sure that you don't lose or drop any of the various washers etc while removing it. Slide the new one in and align the hole and drive the roll pin back in
If it's part 45, then you will need to undo the master link on both chains, drive out both roll pins, slide both axels out. Transfer the parts from the old 45 to the new 45, hold it up in the chassis and slide both axels in. Align the hole through the sprockets and axels and drive the roll pins back in. Put the chains back on and redo the master link.
Anything you have apart that might need lubing, this is a good time to do it (like axel bushings, chain, etc).
I expect this would be easier to do in the service position (auger down, handlebars up), so insure you don't have so much gas it will run out when tipped up (or better yet, drain the tank). I usually go slightly over center and rest the handlebars on the garage wall. When you're done, take it back to normal position and I like to let it set a while as you do have things like oil in the crankcase I like to give a chance to all run back where it's supposed to be.
Good luck, and let us know how it turns out.
