Snow blower doesn't throw snow far enough: - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 11-27-2010, 10:27 PM Thread Starter
I have a 1982, John Deere 826, snowblower that throws snow about half the width of the double driveway. Engine, drivetrain and belts are in good repair. Dealer has rebent paddles on the impeller. I spent probably as much money as the machine is worth, but I like this blower. Any Ideas?
Jack S
Jack S is offline
post #2 of 7 Old 11-27-2010, 11:22 PM
Yeah I hear ya you can make anything a money pit if you want. Only throwing about 8 ft dosnt seem its working right. Do a google on SNOWBLOWER HIGH PERFORMANCE IMPELLER KIT you can come up with some different stuff and opinions. I'm trying a 1/2 inch bigger drive pulley this year roughly 17-18% higher impeller speed. Works excellent in this low lite stuff have to see if I can pull it when the good stuff shows up next month or so
Full Throttle is offline
post #3 of 7 Old 11-28-2010, 06:28 AM
Ya... that doesnt seem right. Is the engine running at the correct speed? A lot of times they are set too low. Bearings starting to get tight?? that will load down the engine. Is there a lot of rust in the housing?
Im guessing thats a two stage blower right?
Ingersoll444 is offline
post #4 of 7 Old 11-28-2010, 04:39 PM
check out this video
This guy puts an impeller kit on his snowblower and it comes back to life.
You can buy the kit from this website Snowblower Impeller Kit I paid $42 total with shipping delivery was pretty quick I just haven't had time to install it yet. You can make your own kit though with some hard rubber and bolts and some metal sheet.
Craftsman 8hp is offline
post #5 of 7 Old 12-01-2010, 03:55 PM
I'm not sure of the year, but I do the snow blowing for my Grandmother with the same model, it will easily toss the snow all the way across her double wide driveway.
Dan
ddrink is offline
post #6 of 7 Old 12-03-2010, 04:39 PM
HDNewf's Avatar
Jack S
Hello Jack S, I'm HDNewf from the Home Depot out of Chicago. Old or not, that's a nice big 10HP machine you have.
+1 Ingersoll444
You should not have to do a "HiPerf mod" your 826 for it to throw snow a lot farther than 8 feet. Engine speed, loose belt or an impeller problem are likely suspects. Why did the dealer "re-bend" the impeller rather than replace it?
Seems odd they let it out of the shop in a poor working condition.
In any event, you can check for a loose belt simply by removing the cover at the front of the engine. If it has run for a while like this you will see the glaze on the belt from slippage. Engine speed you will know by sound. That leaves the "re-bent" impeller.
I hope this helps.
HDNewf
HDNewf is offline
post #7 of 7 Old 12-08-2010, 10:36 AM
engine speed, loose belts or impeller problems. thanks a million bud... thanks for taking your time to write the probable cause.
cosito is offline
Human Verification
