Snow Joe Problem - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 01-17-2014, 08:09 PM Thread Starter
Snow Joe Problem
I have a 13.5 Amp Snow Joe and it works great for a very short time. It seems the thermal protection shuts it off by just blowing a few inches of normal snow for less than 5 minutes.
I have thought of bypassing the thermal device but then I risk burning out the motor.
Any advice? Has anyone had this problem with a Snow Joe?
Tictac is offline
post #2 of 12 Old 01-17-2014, 08:14 PM
Thanks (Received): 179
Likes (Received): 212
Are you using a good thick extension cord? If the gauge of wire is not thick enough it will causes extra heat.
Likes Terrance liked this post
post #3 of 12 Old 01-17-2014, 09:11 PM
Thanks (Given): 165
Thanks (Received): 245
Likes (Given): 945
Likes (Received): 403
hope you are using a heavy duty extension cord
sounds like the same problem my cousin encountered with my electric power washer using a medium duty extension cord
2-toro 521E-38052
1-.............,TORO XL 624..............
1-............, TORO XL 824..............
post #4 of 12 Old 01-17-2014, 09:36 PM Thread Starter
My extension cord is only about 25 feet long, but it is only a light duty one. I'll try with a thicker cord and report back. Thanks for the suggestion, guys.
Tictac is offline
post #5 of 12 Old 01-17-2014, 10:04 PM
I have a 13.5 amp Snow Joe. Instructions said to use a 12 gauge extension cord. If you're not using a heavy duty cord, this is probably your problem.
suzque2 is offline
post #6 of 12 Old 01-17-2014, 10:56 PM
superedge88's Avatar
Thanks (Received): 19
Likes (Received): 10
Ditto
superedge88 is offline
post #7 of 12 Old 01-18-2014, 01:16 PM Thread Starter
I found a 12 guage, 50 foot extension that should be MUCH better. It's the heavy duty one used for campers, etc. The problem is exactly the same. I think I'm going to try and bypass the thermal cutout device and make sure I don't overload the motor. That should tell me if the device needs replacement.
Tictac is offline
post #8 of 12 Old 01-18-2014, 02:34 PM
You could try a different outlet before you go taking the machine apart.
post #9 of 12 Old 01-18-2014, 02:50 PM Thread Starter
The outlet is fine. I have run compressors, electric mowers and table saws off the same outlet. It has a 15Amp GFCI also.
I just took the unit apart (which was a bit of a chore). Lo and behold! The circuit breaker that was attached to the side of the motor is rated at only 5 Amps! This has to be the problem because the unit is advertised as having a 13.5 Amp motor.
I can't find any circuit breaker specs on the web and the manufacturer is closed today. I might just see if I can find a 10 amp breaker and try that. I will report back with results next week.
Tictac is offline
post #10 of 12 Old 01-20-2014, 12:15 PM Thread Starter
After several emails and phone calls, I have contacted a technician at Snow Joe in NJ and explained the situation. He informed me that this unit should have had a 15Amp circuit breaker installed. He is going to ship me one no charge. I'm sure this will solve the problem.
Tictac is offline
Human Verification
