Broken Toro 421 for sale - is it worth it? - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 14 Old 02-15-2017, 07:31 PM
Likes (Received): 24
If your going to look for something, Look for a different machine. A non running machine is only worth $20/$40. The problem is, if it's not running, you can't check anything else, like drivetrain. Most C/L sellers don't want you taking things apart to test anything. And what if you get it running? They say THANX, I'll keep it. OR, Thanx, I want $200 for a RUNNING machine. Best to offer $20 and take your chances. No easy answers, just my experiences....Good AND Bad. Some day's your the bug and some day's your the windshield.
GLuck, Jay
JayzAuto1 is online now
post #12 of 14 Old 02-15-2017, 08:06 PM
Thanks (Given): 166
Thanks (Received): 245
Likes (Given): 956
Likes (Received): 405
if you decide ti get the 421 you can find hard rubber tires on ebay the tires can come from a 421 or 3521. the hard rubber tires can come from a 521 as long as it came with hard rubber tires, the pneumatic tires have a larger axle size so hrt to pneumatic is not a direct swap. I didn't look at the add but if its just the motor that's the problem you might want to put a predator 212 motor on it
2-toro 521E-38052
1-.............,TORO XL 624..............
1-............, TORO XL 824..............
post #13 of 14 Old 02-15-2017, 09:13 PM
Likes (Given): 38
Likes (Received): 18
The WD 40 idea is an old lawnmower trick for starting a dead mower. You took the air filter off and sprayed it liberally down into the carb. And 9 out of 10 times it worked....
toroused is offline
post #14 of 14 Old 02-17-2017, 08:50 AM Thread Starter
Well thanks everyone for all of your tips. I went and checked it out. Plug was fouled up, but I didn't try to hard to start it. The recoil spring was shot, and parts of the body were held on by zip ties. I probably could get it running, but it looked like a money pit - even if it was free. So I passed. Oh well! There will be other fixer upper 2 stage blowers!
WalkThisWhey is offline
Human Verification
