New Deluxe 24 and newb intro - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 12-05-2016, 03:14 PM Thread Starter
Afternoon everyone! I'm combining both an intro post and a question into one, hope you all don't mind.
Anyway, many, many moons ago I was brought into this world and soon after I discovered I needed a snow blower. lol
I had an old yard machines blower that served its purpose for many years, but after many years of not being taken care of, and browsing these evil forums, I picked up an Ariens Deluxe 24 from my local dealer. They assembled and dropped it off.
Yesterday we got some snow in Chicago, not quite enough to warrant using a machine this size, but I had a new toy and wanted to play.
So I fired it up and noticed that the augers were already spinning and when my girlfriend pressed on the handle that controls the auger, it didn't speed up anything. My thought is that the auger shouldn't be spinning unless the handle is depressed. Just looking for some info.
Side note, that 2 stage yard machines will be for sale if anyone is interested, needs a carb (that I might have), sheer pin, and some TLC.
ekaz is offline
post #2 of 9 Old 12-05-2016, 03:16 PM
Likes (Received): 1382
ALOHA from the paradise city.
post #3 of 9 Old 12-05-2016, 04:37 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 420
Likes (Received): 664
welcome to the forum ekaz.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #4 of 9 Old 12-05-2016, 06:06 PM
Thanks (Given): 10
Thanks (Received): 11
Likes (Received): 8
ekaz ,
I also have a new Ariens Deluxe 24. Haven't used it in snow yet. It was delivered to me from the factory, so I got to do all of the set up on it, which included adjusting the cables for the auger and the clutch for the drive wheels.
The auger should not be turning unless the handle is depressed. If you then also press the handle for the drive wheels, you can let up on the handle for auger and they will keep turning until you let up on drive wheel handle. If the auger is spinning/turning without the drive wheels engaged and without holding down the auger engagement handle, you can adjust it yourself by using the information in the service manual, which can be downloaded from Ariens. Or, in your case your dealer, if it is not Home Depot or Lowes, should adjust it for you.
You can download the service manual from Ariens here: Ariens Order Owners Manuals
Bob
_____________________
2017 Ariens 921045 (Deluxe 24)
NVA4370 is offline
post #5 of 9 Old 12-05-2016, 06:08 PM
Thanks (Received): 127
Likes (Given): 79
Likes (Received): 172
aboard ekaz!
Good choice with the Deluxe 24. I also had an MTD that served me well for nearly 20 years.
Cardo111 is offline
post #6 of 9 Old 12-05-2016, 06:15 PM Thread Starter
Thanks for the reply! So I wasn't crazy in thinking that the auger shouldn't be spinning.
ekaz is offline
post #7 of 9 Old 12-05-2016, 07:52 PM
Likes (Given): 1885
Likes (Received): 663
hello ekaz, welcome to SBF!! no the auger should not be spinning that is unless the lever is depressed
post #8 of 9 Old 12-06-2016, 09:02 AM
I got a Deluxe 24 last February myself. My auger was doing the same thing, even though it was setup by a dealer. I believe all you have to do is pull the cotter pin at the bottom of the auger control near the base of the unit. Then you just screw in a little more length into the control rod. It just has a little too much tension on it. So it is not completely disengaging. It only takes a couple of minutes to do. Good luck, and congrats on you new Ariens.
Ariens 24" Deluxe
My First Snowblower
No No No I don't shovel it no more.
Got tired of waking up on the floor.
Smitty4ut is offline
post #9 of 9 Old 12-06-2016, 01:34 PM Thread Starter
I was just looking at the manual and will adjust it. Supposed to get 50" of snow this year and as much as I dislike snow removal, I'm kind of looking forward to it this year. And not content to leave well enough alone, been looking at the HID upgrade. This forum is almost as bad as the car forums when it comes to modding. haha
ekaz is offline
