Does this Youtube expert describe the Wrong way to check the oil level on my AX 254? - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 12-27-2016, 05:16 PM Thread Starter
My Deluxe 24 came overfilled according to the manual. If I rested the cap on the fill tube it read correctly but if I screwed the cap down to take my reading it was well over the full indicator. I thought it was just a quick and dirty fill job by the tech at CDA Tractors but this guy does it wrong too according to the engine book that came with my machine.
This guy sounds like he knows what he's doing but when I read the engine manual that came with my SB it reads...
"Insert the dipstick into the filler neck and turn clockwise until fully seated. Then remove the dipstick by turning it counter-clockwise. Check the oil level shown on the dipstick.(179/208/254cc only)."
I have a '16 Deluxe 24 and it looks like his 28 has the same 254cc engine I have.
If I'm missing something please let me know. I'm doing my first oil change today and want to make sure I'm doing it right.
The part about the dipstick is at about 1:45.
Eric is offline
post #2 of 18 Old 12-27-2016, 05:37 PM
Thanks (Given): 102
Likes (Given): 274
Eric, if your Owner's Manual says to screw it all the way down to check the level, that's what you fly with.
uberT is offline
Likes Cardo111, Mike C. liked this post
post #3 of 18 Old 12-27-2016, 06:41 PM Thread Starter
How right you are!
I just finished the oil change the way the manual says to do it. When I first got the machine I drained 2 3/4 oz of oil out of it to get it down to the full mark as per the manual. Today I drained it completely and there were almost exactly 20 oz in it. I refilled it with 20 oz of fresh oil as listed in the manual and the dipstick reads exactly "Full" when screwed down tight. If I do the lightly resting the cap on the fill tube like shown in the video it reads "Add."
Eric is offline
post #4 of 18 Old 12-27-2016, 07:29 PM
Thanks (Given): 16
Likes (Received): 11
This is very interesting. I always screwed it all the way down on my old Tecumsehs. Now I'm wondering - is that what you're supposed to do in general?
My machine:
Stang is offline
post #5 of 18 Old 12-27-2016, 07:33 PM
Likes (Received): 303
Originally Posted by Eric View Post
How right you are!
How did you drain the 2 and 3/4oz's?
post #6 of 18 Old 12-27-2016, 08:11 PM Thread Starter
I just unscrewed the cap to where the oil started to drain, let a little drain and then capped it back up. Then I checked the level the way the manual described and drained a little more until it read Full. I checked the level the next day to make sure I had it right.
Eric is offline
post #7 of 18 Old 12-27-2016, 09:37 PM
Thanks (Received): 21
Likes (Received): 52
seriously. Does an 1/8" really matter anyway? Of course not.
NJHonda is offline
post #8 of 18 Old 12-27-2016, 11:01 PM Thread Starter
Thanks for letting me know.
Eric is offline
post #9 of 18 Old 12-28-2016, 11:45 AM
no problem. Don't sweat little things like that. I know guys who don't even change or check oil in their small engines for years. And they run forever
NJHonda is offline
post #10 of 18 Old 12-28-2016, 12:36 PM
Thanks (Given): 72
Thanks (Received): 398
Likes (Given): 183
Likes (Received): 931
Except it could be a lot more than 1/8 of an inch..
The threads on the cap on the video look pretty deep, the yellow cap is thick:
which means just resting the cap, versus screwing it all the way down, could be 3/4 of an inch, maybe even close to an inch in some cases, depending on the cap design. So the difference between the two methods could be significant.
The moral is: just do what the manual says! disregard videos, or anything else, if they contradict the manual.
the manual always wins.
Likes Mike C., classiccat liked this post
