Ariens 72/73 910995, was running well, now seems no spark - Snowblower Forum : Snow Blower Forums
post #1 of 37 Old 12-27-2016, 11:54 PM Thread Starter
I picked up this thing for $50 and got it running well and it just chugs through the snow like nobody's business, however the last time I ran it the blower had a hard time starting and this time I couldn't get it to start. It has fuel, oil, turns over, but won't fire.
I pulled the plug to check if there was spark while turning it over and there was nothing at the electrode, however the wire was shocking the **** out of me so I know there is power getting to the end of the wire. Same thing if I put my finger on the end of the boot directly above the spark plug.
I figured that maybe the inside of the boot was rusted so I took a small file and cleaned the contact point in the boot and then used some dielectric grease, still no firing.
I then pulled a plug from a working blower just to see if I could visually see spark at the end of the plug and I couldn't (I ended up using that snowblower to do the job tonight).
I tested the "test plug" and it worked on the other machine, but not the machine in question.
I'm kind of at a loss here as there is "Juice" all the way to the plug, but not passing through it. Could it be that the voltage is too low to generate spark in the plug end? This is about the only thing I can think of.
Any input/suggestions or other trouble shooting you can think of. I've put about 5-6 hours on this thing this year and ran great until this happened
Additional Specs I've collected:
Ariens Snow blower 91008
24" 910995 snow thrower
Ariens IBM Number: 82014
Original Engine number: H70-130067A
Engine Number: 907300A
ShortBlock Number: 756180A
Engine Should be Governed t0 3600RPMs
Spark Plug: J8C or J17LM (J8C installed)
live4soccer7 is offline
post #2 of 37 Old 12-28-2016, 12:03 AM
Likes (Received): 1384
better check the points on that 1 there.
post #3 of 37 Old 12-28-2016, 12:09 AM Thread Starter
Those are on the magneto behind the flywheel, correct?
post #4 of 37 Old 12-28-2016, 01:00 AM
Yep behind the flywheel.
post #5 of 37 Old 12-28-2016, 01:16 AM Thread Starter
anything in particular I need to watch for when disassembly the flywheel. Items/markings associated with timing etc...? Thanks, the starter just seized and burned up. It's been a great day of plowing. haha.
post #6 of 37 Old 12-28-2016, 01:51 AM
No timing marks. might need a puller though.
post #7 of 37 Old 12-28-2016, 02:40 AM Thread Starter
The flywheel is on there pretty dang well. Kind of weird you have to pull 3 headbolts to remove that cover. Kind of a bad design really. It is leaking oil from the head gasket area.
I'm thinking a few things may need taken care of it I'm taking it this far apart. Any recommendations on all parts I should get?
I need a new starter, head gasket, i've done the carb and it's good now.
I did not see any threaded points in the flywheel for a puller, unless it is a rather large puller that grabs on behind the flywheel???
post #8 of 37 Old 12-28-2016, 02:46 AM
Yeah they have those clamp style ones that grab the edge of the wheel.
post #9 of 37 Old 12-28-2016, 02:48 AM
might want to have a looksee at the valves and rings. check the breather out also. what do the cylinder walls look like??????????????? post some pics 4 me.
post #10 of 37 Old 12-28-2016, 02:49 AM Thread Starter
Don't know that I have a puller that big. Might have to bust out the welder and make something.
