Heated grips - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 01-07-2017, 09:30 PM Thread Starter
Likes (Received): 11
Heated grips
Can you put heated grips on a compact 22?
Is the alternator powerful enough to handle it?
ax engine
BeerGhost is offline
post #2 of 13 Old 01-07-2017, 09:39 PM
Thanks (Received): 98
Likes (Received): 260
Read this. If you currently have a light, and know anything about wiring, you can have a setup with either full heat, full light, or 1/2 heat and 1/2 lights. And it is very in-expensive if you can wait for the boat from China.
https://www.snowblowerforum.com/forum...and-grips.html
RIT333 is online now
post #3 of 13 Old 01-08-2017, 12:39 AM
Thanks (Given): 20
Likes (Given): 48
Likes (Received): 23
RIT333, the Ariens 924024 gets heated grips as soon as they arrive
Ariens 924024 8 hp 32 now a 10 hp
Ariens 910008 7 hp 24
Ian Ariens 924 is offline
post #4 of 13 Old 01-08-2017, 12:18 PM
Thanks (Given): 589
Likes (Given): 4362
Likes (Received): 1741
Don't get the really cheap ones from China. I did that and they are really cheap. Better to get the Ariens or Toro factory units or some mid priced ones for motorcycles or snowmobiles.
Just my .
post #5 of 13 Old 01-08-2017, 01:30 PM
Yeah - but he doesn't have that model.
post #6 of 13 Old 01-08-2017, 01:34 PM
Just my .
My cheap Chinese ones are still working fine. I usually have to turn them off after awhile because my hands get too warm. But, I can't use them at night because my alternator does not put out enough power to drive the HHGs and light to a sufficient brightness. But, I usually don't snow blow at night anyways.
post #7 of 13 Old 01-09-2017, 07:10 PM Thread Starter
The engine has a 60 watt alt.
I am going to get the ariens heated grips.
post #8 of 13 Old 01-28-2017, 02:40 PM Thread Starter
The Ariens heated grips are on. Man do they put out some heat.
Instructions say to install grips with wires facing dash but the auger n drive levers nip at the wiring.
Ended up installing grips with the wires facing down.
Model 920013 LCT 208 CC 60 watt alt.
heated grip kit # 72101400
post #9 of 13 Old 03-16-2017, 01:29 PM
Likes (Given): 7
Beerghost, did you find your alternator specs online? I have 2016 model Compact 24 and am thinking I'd like to add heated grips.
Also, did you purchase directly from Ariens or a dealer, and what was your cost?
redcon1 is offline
post #10 of 13 Old 03-17-2017, 04:02 PM
60w like most of the LCT engines, see item 60 of:
https://www.jackssmallengines.com/ja...ngine-08200807
djc11369 is offline
