Is a Ariens st724 that needs work for $50 worth it? - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 01-15-2017, 09:44 PM Thread Starter
orangputeh's Avatar
Thanks (Given): 762
Thanks (Received): 235
Likes (Given): 1581
Likes (Received): 1666
Never owned an Ariens so don't know anything about them. This is an a ST724 , not sure how old that the guy has put a lot of work into. a new carb and he bought some piston rings for it and not sure why.
it smokes a little and gets very hot and screams when running. did not want to run it and maybe blow the motor so not sure if everything else works. he says it does.
he only wants $50 for it so would you take a chance on it? would it be worth fixing or maybe for parts? I see they sell from about 250-400 on craigs.
i just don't want to get started on a possible money pit.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #2 of 10 Old 01-15-2017, 10:02 PM
Thanks (Given): 173
Likes (Given): 457
Likes (Received): 1034
Watch vid ad make your descision.
If I were in the market for a blower and this one is in good overall condition I'd definitely get it. Stick a Predator engine on it if engine tosses a rod.
I have one of these... Nice machine.
post #3 of 10 Old 01-15-2017, 10:43 PM Thread Starter
orangputeh's Avatar
Thanks (Given): 762
Likes (Given): 1581
thanks joe. how much is one of those engines?
post #4 of 10 Old 01-15-2017, 11:10 PM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
GEvening O/P, Can't really go wrong with a running Ariens for $50, as you could part it out if things go sideways. It would be a cheap learning experience if nothing else. I'd grab it, if for nothing but parts. But before cutting it up, try getting the engine squared away, BEFORE it blows!!! GLuck, Jay
JayzAuto1 is offline
post #5 of 10 Old 01-15-2017, 11:33 PM
Likes (Given): 35
Likes (Received): 15
Horrible Fart sells them for 120 bucks, with occasional sales at 100.
JD in NJ is offline
post #6 of 10 Old 01-16-2017, 12:59 AM
it sounds like a governer issue, if your lucky he hasnt run it like that long enough to cause any real damage, but if it has some serious engine damage you can buy a predator. either way for 50 bucks you cant loose in my opinion. just make sure the model number starts with 924 before you buy it(924 series machines use single shaft engines) they made more then one version of the st724 a full size 924 series one and a compact version
post #7 of 10 Old 01-16-2017, 06:09 AM
Thanks (Given): 173
Likes (Given): 457
From what I understand Harbor Freight has them for around $100-120.
That problem does sound like a governor problem. It's possible it is stuck.
I bought an edger that had been sitting out for a while and was a bear to start. When it would start it would immediately go to WOT. I checked it out and all that was wrong was that it had stuck and all it needed was a little lubrication. It starts first pull now, and runs fine.
post #8 of 10 Old 01-16-2017, 06:23 AM
Likes (Received): 42
The weak point with this model was the gear case. Plenty of good carcasses out there with a blown gear. MH
1960 Ariens 45-10M
1961 Ariens 10M55
1977 Ariens 22000
1972 Ariens 10000
1990 Ariens ST724
1987 Toro 724
Murray Ultra 522
MTD Single stage
8 hp MTD hybrid plow
motorhead64 is offline
post #9 of 10 Old 01-16-2017, 12:41 PM
Thanks (Received): 212
Likes (Received): 767
I repowered a ST 724 about ten years ago and love its operation. The Predator swap is perfect for this blower.
cranman is offline
post #10 of 10 Old 01-16-2017, 08:29 PM
Thanks (Given): 7
Likes (Given): 48
Likes (Received): 20
I'd say go for it, as the Predators are easily available and there is usually a $99 coupon in most of their catalogs I get each month.
Adam
Flathead Valley, MT
1980 Ariens ST824
1990s Toro CCR1000
The_Geologist is offline
