Just Picked Up This Free ST824 - Snowblower Forum : Snow Blower Forums
post #1 of 23 Old 01-26-2017, 07:39 PM Thread Starter
orangputeh's Avatar
Thanks (Given): 762
Thanks (Received): 235
Likes (Given): 1581
Likes (Received): 1669
It runs but rough and needs a throttle cable, a new recoil starter and some carb work.
It was free so I'd thought I would give it a try. never worked on an Ariens before, just Hondas.
I am only going by what the owner told me. She was using it four days ago when it quit. Gonna give it a try or part out.
Where is the best online source for parts?
Here are some pics.
ID:	98217   Click image for larger version
ID:	98225   Click image for larger version
ID:	98233   Click image for larger version
ID:	98241   Click image for larger version
"It Feels Like Beer O'Clock "
orangputeh is online now
post #2 of 23 Old 01-26-2017, 07:47 PM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
Looks like you need a new cutting edge.
post #3 of 23 Old 01-26-2017, 07:48 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 419
Likes (Received): 664
as a freebee, it appears you have a keeper !! i would look it over well, replace all normal wear parts and maybe do a repower . sure wish i could find free ones !
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #4 of 23 Old 01-26-2017, 09:03 PM Thread Starter
orangputeh's Avatar
Thanks (Given): 762
Likes (Given): 1581
where would I get parts ? I looked on ebay and amazon and not much there or maybe I'll wait till summer to find a donor machine.
post #5 of 23 Old 01-26-2017, 10:59 PM
Thanks (Received): 39
Likes (Given): 53
Likes (Received): 100
Your local dealer should have most every thing you need. Also jacks has all the parts you need too
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
post #6 of 23 Old 01-26-2017, 11:27 PM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 192
Nice freebie !!!
Missing heater box on the carb, broken locking pin and missing knob for the differential. Does not have 120v starter, but probably has ring gear. But it is the big wheel model.
Only downfall on that machine is the aluminum gearbox. Id go through it as I do my machines. Regardless of whats on there now and condition... if im keeping it I would replace these items ....
Axle bearings 20 each, friction wheel 15, reduction drive chains & master links 20, reduction drive bearings 20, belts 25, auger bushings 10, scraper blade & bolts 20, professional shoes 40, 00 grease for gearbox 6, impeller bearing 10, possibly the friction plate bearings if needed 20. The rest is labor and lube for moving parts. Carb rebuild and spark plug if needed.
If you do these repairs you will have a mechanically sound machine, depending on the engine condition .... very reliable. See how worn the gearbox is, replace if needed 240 for a cast iron unit. I buy my parts between two places, Jacks small engine and Pats small engine. Probably 5 or so hours labor depending how hard it comes apart.
She's a keeper if you need a great 24" Machine.
Just checked for repower Briggs & Strattons with ac alternator & 120v starters...
16.50 Gross Torque { Approx 12HP } is about $250 including shipping, but will require a 3/4 to 1" shaft adapter and also weld in / bolt on mounting studs / bolts.
14.50 Gross Torque { Approx 10HP } is about $230 including shipping, but will require a 3/4 to 1" shaft adapter and also weld in / bolt on mounting studs / bolts.
Also they have a 12.5 HP engine from LCT with ac alternator and 120v starter for about $220 including shipping, has 1" crank, but will have to weld in / bolt on mounting studs / bolts. I just installed one of these on a 32" ariens and it has tons of power, but I do not like the 120v starter, sounds cheap / noisy when starting. See pixx of the lct engine below.
If your keeping it you have lots of options, if your flipping it do the basic things it needs and then buy exactly what you want.
For S & G I looked at craigslist in Tahoe and did not find much at all, lots of good donor machines here in new England.
ID:	98273   Click image for larger version
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is online now
Thanks orangputeh, jrom thanked for this post
Likes jrom liked this post
post #7 of 23 Old 01-27-2017, 12:15 AM Thread Starter
orangputeh's Avatar
Thanks (Given): 762
Likes (Given): 1581
Originally Posted by Shaw351 View Post
Nice freebie !!!
thanks!
that is why i posted the pics so people could point out what i need. i was looking for an ariens repair manual with diagrams so i could what parts are missing and how it goes together.
post #8 of 23 Old 01-27-2017, 12:25 AM
Thanks (Given): 40
Likes (Given): 48
Believe this is your machine parts breakdown.
http://apache.ariens.com/manuals/PM-24-79.pdf
With prices , but shop around to compare.
Ariens 924050 Parts List and Diagram - (036501) : eReplacementParts.com
~~ And Lastly ~~
post #9 of 23 Old 01-27-2017, 02:15 AM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 268
you'll find parts for it no problem. It's a keeper. The bucket looks to be in good shape.
GoBlowSnow is offline
post #10 of 23 Old 01-27-2017, 04:20 AM
Likes (Given): 1882
Likes (Received): 663
nice score
