Ariens questions - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 02-07-2017, 08:15 PM Thread Starter
Thanks (Given): 80
Thanks (Received): 17
Likes (Received): 15
Ariens questions
1980 st724 model 924048 ser. 007049.
I noticed 2 things. The chute has zero resistance and the knob just flops. For the direction adjustment.... is there a preload screw to tighten it up?
2nd question is this model has the axle/diff lock. The lock at the hub works but see no engagement. I tried a few tricks but nothing seems to work... suggestions?
Sent from my SM-N900P using Tapatalk
96 Mustang - Race car
2005 Mustang - Daily Driver
15 Grand Cherokee Altitude - Mall Crawler
2007 Anderson Open Deck 19ft Trailer
1998 828D John Deere
1996 828D John Deere
2015 D110 John deere
ST724 Ariens not sure of year
1978 Ariens 924000
1964 10ML60D
Duff Daddy is offline
post #2 of 3 Old 02-07-2017, 09:47 PM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 192
Sounds like a missing or broken roll pin in your chute rod control setup, or possibly broken u-joint.
The differential on those machines have three positions where the lock pin will drop into the locating hole and engage the positraction feature. Look closely at the rim where the lug bolts are and you will see the three holes of which i speak of.
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is online now
post #3 of 3 Old 07-16-2019, 02:53 PM
Did you get it fixed?
Nordic is offline
