924032 drive engagement problem - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 02-11-2017, 01:21 PM Thread Starter
Likes (Received): 39
I've had trouble with the drive engagement freezing up when it's super cold. Looking deeeeeeeeep into it, I see the pulley and drive disk go through a bearing that slides rearward to engage the drive against the friction wheel. I'll have to disassemble and clean this up. What grease/oil should I use on this sliding bearing?
nt40lanman is offline
post #2 of 7 Old 02-11-2017, 02:12 PM
Thanks (Received): 212
Likes (Received): 767
I use PB blast to loosen up any old grease, then work it up and down with a crowbar until nice and free, then spray lithium grease in it
cranman is offline
post #3 of 7 Old 02-11-2017, 02:22 PM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 192
Those assemblys do get grungy & sticky due to age and type of lubricant that was used. When they get really stiff its nearly impossible to adjust drive as the spring assembly will just stretch rather than engage friction plate to the wheel. I use pb blaster or kroil to loosen it up and i remove friction wheel ( 5 bolts ) so that i can have more free movement area to work the plate assembly back and fourth. That usually does the trick to get it freed up and working normally. Then i use Zep 2000 lubricant and work it in, goes on as a liquid then somewhat solidifies to a grease.
Worse case is to remove the friction plate assembly and install two new bearings. Not too hard of a job if your mechanically inclined. Just know that it is left hand threaded, and washer / spacer placement is Critical.
Take pixx as you disassemble, washer in wrong place will bind up pulley.
Good luck and let us know how your repair goes.
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is offline
post #4 of 7 Old 02-11-2017, 02:24 PM
Thanks (Given): 40
Likes (Given): 48
Originally Posted by cranman View Post
i use pb blast to loosen up any old grease, then work it up and down with a crowbar until nice and free, then spray lithium grease in it
Ditto
~~ And Lastly ~~
Shaw351 is offline
post #5 of 7 Old 02-12-2017, 04:28 AM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
These guys are pretty sharp, and I'd like to add my .02. I use non-chlorinated brake cleaner to dissolve the contaminants, simply for the fact that I'm a slob, can't see very well, and have fat fingers, so any more lubricant on that rubber wheel, rears it's ugly head, AFTER I assemble it, give it to the customer, then wait for the phone call saying that his recently serviced machine feels as it's slipping. For the re-lubing, I use the black synthetic brake grease on the hex shaft.....for the same reasons, I'm sloppy and don't have good aim. I work it on the shaft quite a few times, won't drip and isn't affected by temperature. Meaning it won't drip off when hot, or thicken up when cold.
Different procedures for different parts of the country. but you can't go wrong with either of the first 2 answers.
HTH, Jay
JayzAuto1 is offline
post #6 of 7 Old 02-12-2017, 08:15 AM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
+1 to Cranman, Also Check the Adjustment. Sometimes a turn or 2 on the nut will help.
Jackmels is offline
post #7 of 7 Old 02-12-2017, 01:36 PM Thread Starter
I soaked it with WD40 just to get going but I'm inclined to disassemble the whole works when it warms up. Problem with that joint is there's a lot of surface area. Good thinking on the brake grease, Jack. I wrench one day a week and we have packets of the stuff everywhere.
