Ariens 11526 Pro Snow Blower Model:926005 - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 02-12-2017, 09:27 PM Thread Starter
Likes (Given): 14
This Ariens 11526 Pro Snow Blower Model:926005 has a joystick to maneuver the chute. 3 years ago I heard there was an upgrade changing out the half moon gear on top of the chute to the new finer tooth gear for better chute stability, locking the chute in smaller increments. Problem is when I move the lever to swing the chute it tends to get stuck in a tooth and it won't swing or it won't lock and it swings around uncontrollably until it eventually it grips a tooth and locks. I have tweaked the cable many times for 2 to 3 seasons now. It works fine for about an hour then messes up from time to time and progressively gets worse the more you use it. Has anyone else changed to this new and improved upgrade and have the same problem or does anyone know what might be the problem?
sjm1027 is offline
post #2 of 12 Old 02-12-2017, 09:44 PM Thread Starter
Likes (Given): 14
Adding some picture showing the cable routing
ID:	99850   Click image for larger version
ID:	99858   Click image for larger version
sjm1027 is offline
post #3 of 12 Old 02-12-2017, 10:22 PM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
I had to put the kit in my Ariens. The chute was swinging, like yours. And it didn't start doing this until quite a few years of owning it.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #4 of 12 Old 02-13-2017, 12:48 AM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
I didn't know they had a kit....Hmmmm. Anybody got a part number??? But up to this point, what I have been doing, is removing the lock piece (the gold one), as it's usually squished together. I spread it out, to a point that fits the teeth of the big gear better, then I sharpen the teeth on the lock so its a more positive engagement. I tweak the spring so it snaps it back in a little tighter. After re-assembly, I tighten the 9/16 nut underneath the pivot, so it doesn't swing so wildly, and now takes effort. Has been working fairly well so far, but it's only been a few storms in.
Thanx, Jay
JayzAuto1 is offline
post #5 of 12 Old 02-13-2017, 01:37 AM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 268
I don't like those things either. They should just stick with the trusty reliable cork screw/hand crank to move the chute.
GoBlowSnow is offline
post #6 of 12 Old 02-13-2017, 05:21 PM
Motor City's Avatar
I think its this part # 52609100
Ariens ST11528LE
Honda HS720
post #7 of 12 Old 02-13-2017, 10:17 PM Thread Starter
Likes (Given): 14
Well I adjusted the cable again tonight. Works good again for now. I need to get to the bottom of this. The chute was stuck in one position today I had to pull on the cable gear logo under the handles to free it up. So nothing like a 2 handed chute move to make the snow removal go fast.
This is the part I am talking about. I have to adjust the cable often
RepairClinic Item #1771803 | Ariens Genuine OEM Part #52609100
sjm1027 is offline
post #8 of 12 Old 02-13-2017, 10:30 PM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 147
Likes (Received): 297
I have that kit but have not yet used it as it was the replacement for the stripprd one on the 1027 I am rebuilding, just playing with it, It seems to work well but no snow or pressure on it to see if it holds up or not.
Dauntae is online now
post #9 of 12 Old 02-14-2017, 08:19 AM
Thanks (Received): 98
Likes (Received): 260
I have a 926001 and have never had any issue with the chute control from Day 1. I love it. Not sure why others have issues. Maybe mine came with the kit already installed at the factory ???
RIT333 is online now
post #10 of 12 Old 02-14-2017, 09:42 PM Thread Starter
Likes (Given): 14
Hi,
Any chance you could explain how your cable is routed. Maybe a pic or explanation? I have a pic above. Is it routed like mine?
sjm1027 is offline
