EFI engines more powerful than carbureted equivalents? - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 02-19-2017, 09:52 PM Thread Starter
Thanks (Given): 178
Thanks (Received): 345
Likes (Given): 483
Likes (Received): 852
I've seen some posts about the new EFI engines, which sound really nice.
People often appear to mention that these engines kind of grunt and power through heavy loads better than they might have been expecting.
This makes me curious, are EFI engines actually more powerful than the carbureted versions of those same-displacement engines? Is this a bit like OHV engines being more powerful than the L-head versions of the same displacement?
Is it possible that some of the reaction is because there's an electronic governor that should be able to hold the RPM more accurately than a mechanical governor? That could at least help perception, such as if the machine's RPM never varied at all, until it was finally overwhelmed by the load.
I've observed my Tecumseh engine bogging down noticeably, and it still didn't open the throttle plate fully, so I know that mechanical governors are not perfect. And until I removed the heater box while putting a load on it, I thought the engine was running out of power, until I saw the throttle plate still wasn't being opened all the way. It helped give a poorer impression of the engine's abilities.
I guess I'm wondering what's a realistic expectation for EFI. Presumably easier starting, fewer adjustments, hopefully more tolerance for old gas, and maybe better fuel economy. But also more power?
I'm not taking anything away from people's experiences, or doubting the reports, or anything like that. Just curious.
I'd love to see side-by-side testing of an EFI blower vs a carbureted version of the same machine, in heavy snow.
post #2 of 15 Old 02-19-2017, 10:10 PM
Likes (Received): 23
doubt if there is any tolerance for old, stale gas you dump into the tank. if you mean gas that's been in the tank awhile I imagine since everything is virtually airtight gas will last a lot longer. as to the question of more power it's probably not a significant amount, just a more precise metering of fuel to air for all atmospheric conditions would seem to indicate a consistent maximum torque and power output for the engine design.
524SWE is offline
post #3 of 15 Old 02-19-2017, 11:14 PM
Same power one just delivers it faster and smoother. Also EFI has many advantages elevation , smoother idle , better fuel efficiency. Mine just adds power as needed quickly smoothly. My MTD carb machine would just take longer to respond which can mean a stall.
kaos is offline
post #4 of 15 Old 02-20-2017, 12:31 AM
Thanks (Received): 25
Likes (Received): 31
Ideally they'd be the same but this assumes a cleaned and properly functioning carburetor which isn't often the case as the machine ages. What you gain in EFI is virtually no lag since the mechanical governor is gone and theoretically vastly reduced fuel consumption if the computer is programmed to idle down when its not under any demand.
SnoThro is offline
post #5 of 15 Old 02-20-2017, 02:43 PM
Thanks (Given): 26
Likes (Given): 24
Likes (Received): 22
My old MTD had a power rating of 10 hp. My EFI Ariens Platinum 24 has about 11.7 hp (21 ft. lb. converted to HP presuming 3600 RPM) - only a 17% increase.
But, measured by how each machine functioned under load - the difference is a lot more than 17%.
My MTD would always bog down in the heavy stuff, and quit if pushed too hard. The EFI does the opposite - it becomes angry. It's never quit. Even with the power dial wide open, the RPM's stay steady, or even accelerate as the load becomes more difficult.
By that measure, the EFI feels like more than twice the power of my MTD. Of course, that's a subjective assessment.
The real test is to compare an EFI machine with it's carbureted counterpart. I'd be interested to read a post by someone who's made that comparison.
Strato is offline
post #6 of 15 Old 02-20-2017, 03:09 PM Thread Starter
Thanks (Given): 178
Likes (Given): 483
That's an interesting point about RPMs. Does the engine speed really increase under a heavy load? The control system would presumably have the ability to do that, if it wanted. Up until the throttle plate is opened fully, of course. I confess I'd assumed the system would simply try to hold a given RPM, based on the power dial setting, but they could have designed the system differently/better than that, of course.
Having a tachometer mounted to one of these engines could be interesting. To see the RPM range for the power dial, as well as to see what it does under a heavy load (holds at 3600? Increases to 3800?).
On a single-stage 2-stroke fixed-RPM blower, I once mounted a string to the governor, allowing me to increase the RPM on-demand. I have been kind of curious to try that on my current 2-stage, to see if the engine still actually has more to give, as it starts to bog down. Just to see how well the mechanical governor is doing its job.
post #7 of 15 Old 02-20-2017, 03:46 PM
The engine literally feels the torque load increase and then adapts. If you hit a heavy area of snow the thing definitely cranks up the engine rpm. Then it idles back down......
It feels like a downshift in a car.....kinda, sorta.
The disadvantage is the cost of a new EFI battery every few yrs. 28.95 or so.......
kaos is offline
post #8 of 15 Old 02-20-2017, 04:16 PM
Thanks (Given): 26
Likes (Given): 24
My experience is exactly the same. Once the CPU senses a heavier load, the engine surges. It's not subtle.
Regarding the EFI battery, the folks at Ariens told me they should last about 5 years.
Strato is offline
post #9 of 15 Old 02-20-2017, 05:50 PM
Likes (Received): 19
Some manufacturers have used mechanical (centrifugal) governors (like Suzuki) vs the more common air vane governors that you see on Briggs and Tecumseh engines. Not sure if they are really better or not but I'm sure EFI will result in better fuel atomization and resultant improved cold starting and running. However, the era of cheap to repair OPE will start to come to a close once they become universal.
1998 Toro 3000 GTS with Suzuki 47p 2 cycle
LouC is offline
post #10 of 15 Old 02-20-2017, 06:02 PM Thread Starter
Thanks (Given): 178
Likes (Given): 483
I'm used to seeing internal, centrifugal governors on my Tecumseh engines, at least. I want to say my Briggs tractor engines have also been internal governors, but I can't say for sure.
I can think of external, air-vane governors that used a pivoting plastic "flag" that responded to air blowing off the flywheel fins. But that was on 3.5hp Briggs mower engines that I was messing with quite a while ago, as a kid Are those the style you're referring to?
Interesting point about OPE repair costs. At first I'm sure the parts will be expensive. But as they go mainstream, hopefully costs will go down, especially if aftermarket options become available. And if the parts are reliable, that should help, at least.
For those of us who buy our equipment used, I could unfortunately see it reducing the number of good deals on machines that just "won't start this season". That's good for the current owners, of course.
