Ariens Pro Re-Power - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 02-25-2017, 06:15 PM Thread Starter
Likes (Received): 6
Ariens Pro Re-Power
Hi, I am looking to re power an Ariens Pro, 2008/2009, ST9526DLE model #926017. The blower came with a Techumseh OHV 318 cc.
I would like to go as large as possible (420cc). I have been chasing model numbers and serials for direct swaps. I know that the frame on mine and a few years forward are the same. It would be a direct swap for a B&S 16.5. I was hoping to use some other model #s with serials to see if the 420cc was ever put on the frame which mine has. I know that the new Pros have a different frame.
Anybody out there with a Pro from 2102, 2013 or 2014 with a 420 cc that I could use the model and serial number to see if the frame is the same as the one in which I own.
mfrs2000 is offline
post #2 of 3 Old 02-25-2017, 06:45 PM
Thanks (Given): 40
Likes (Given): 48
Likes (Received): 192
Don't drive yourself crazy with model and serial numbers, first check to see that is a single output shaft which I believe it would be on that machine. Meaning belts are only run off the crankshaft output, probably a 1 inch diameter shaft. Some models have two output shafts a smaller one for the transmission and a larger one for the augers. If you have a single output shaft, you have many options to repower that machine. Usually on motor swaps it is just a matter of a different bolt pattern in the chassis going from a smaller motor to a bigger one, possibly longer belts which you can get locally, and sometimes you can find a really good deal on a larger motor with a three-quarter inch shaft, in which case you just get a shaft adapter - 1 inch to fit your original pulley.
Post up a picture or two of your machine with the chute & controls, sometimes they might need to be modified.
If you are comfortable doing your own work, the members here will walk you through the process.
Good luck on your project.
Ariens 24" 910962 7HP
~~ And Lastly ~~
Shaw351 is online now
post #3 of 3 Old 02-25-2017, 06:54 PM
Likes (Received): 82
At first look it might be a tight fit as mine was and it won't be a direct swap. Where the engine bolts on right now, is the frame square or has bevelled sides at the top and side where they meet? The pulleys will be an easy fit depending on the brand of engine contemplated such as length of main shaft.
Could you tell us where you live approx.?
Definitively not an impossible project but need some details first.
Good Luck
Norm
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
