chute lubricant - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 03-07-2017, 06:33 PM Thread Starter
Thanks (Received): 99
Likes (Given): 68
Likes (Received): 223
chute lubricant
I have 2004 1332le is it ok to use grease under the chute?? i have it off to put my impeller kit on
thanks
1132le is offline
post #2 of 9 Old 03-07-2017, 07:17 PM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
Grease and oil attract dirt, I prefer not to use either, if I do use a lubricant in those type of situations, I use a graphite paste, Never-Seize.
post #3 of 9 Old 03-07-2017, 07:39 PM
Likes (Given): 215
Likes (Received): 304
dbert is offline
post #4 of 9 Old 03-07-2017, 08:09 PM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 268
Dirt won't hurt the chute. I use grease/lube. I wipe it off when it gets dirty after a few years and put new stuff on.
GoBlowSnow is offline
Likes Prime liked this post
post #5 of 9 Old 03-08-2017, 12:55 AM
Thanks (Received): 15
Likes (Received): 19
Big variety of opinions here I guess - - - -
I wouldn't use most chain lubes as they're generally made to stick, even at elevated temps
I would use waterproof grease as the environment isnt dirty but it is wet.
Anyone going to speak up for silicone lubes?
cpchriste is online now
post #6 of 9 Old 03-08-2017, 04:27 AM
Likes (Received): 483
I've used Mobil1 grease or snowmobile grease (both design for low temperatures)
post #7 of 9 Old 03-08-2017, 06:57 AM
Thanks (Given): 28
Thanks (Received): 25
Likes (Given): 180
Likes (Received): 41
Agree. Low-temp grease is the way to go.Clean and regrease as needed or any time the chute is off.
Prime is offline
post #8 of 9 Old 03-08-2017, 07:03 AM
Thanks (Given): 28
Likes (Given): 180
Its all good.... until temps get cold. Anything designed for low temperature use should be fine.
Prime is offline
post #9 of 9 Old 03-09-2017, 09:06 AM
Likes (Received): 23
I do lube the chute on my Toro because it's plastic on metal but the chute on my Cub is plastic on plastic so no lube needed.
1995 Toro CCR1000
2007 Cub Cadet 524SWE
524SWE is offline
