do all brand new ariens chutes squeak - Snowblower Forum : Snow Blower Forums
post #1 of 19 Old 01-11-2014, 02:43 PM Thread Starter
I just got done putting my new ariens together an out the crate an I didnt pay much attention to the bottom of the chute while placing it on the housing but is there 2 rubber pieces that is causing the horrible squeking noise while turning the chute.i tried lil more grease on the visible rubber gasket an it never helped .im just curious Its not desl breaker an at the moment its the only thing I can nit pick on .while some time il find more prolly but its just annoying
throttlejunkie450 is offline
post #2 of 19 Old 01-11-2014, 03:03 PM
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
Here's the instructions from the assembly manual page that talks about putting the chute on. It shouldn't squeak. At all. If it were mine, I'd take it off and make sure the underside is well greased. Otherwise it will likely bind and give you trouble.
1. Grease underside of discharge chute ring (if not already greased).
2. Remove mounting hardware from auger housing.
3. Install discharge chute over opening in the auger housing. Finger tighten the mounting hardware removed above.
NOTE: Leave discharge chute pedestal loose to help install the chute crank.
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
post #3 of 19 Old 01-11-2014, 03:39 PM
What material and what temperatures are we dealing with?
In car suspensions it is very common to replace sway bar link ends and pick up a squeek when it is cold out because of the tight fit of the clean bushings. I believe it's polyurethane that does this.
Don't take this advice to seriously however, we are not comparing apples to apples here.
scipper77 is offline
post #4 of 19 Old 01-11-2014, 03:47 PM
Likes (Given): 266
It should move like it was on ball bearings. It should not squeak.
Larry
post #5 of 19 Old 01-11-2014, 08:51 PM
Rubber pieces? Not sure what you mean.
There are 2 friction washers that mount where the chute attaches to the pedestal. These aren't rubber though. I've heard these squeak before, but usually when it is clamped too tight.
Snowmann is offline
post #6 of 19 Old 01-12-2014, 03:00 AM Thread Starter
Im not sure how I have it to tight since it just sits onto the housing an is mounted to a arm with 2 bolts .I can wiggle the chute by hand a lil bit.i had white lithium grease which shouldnt be a problem I wouldnt think.it what was in the garage I put it together in since the delivery driver couldnt make it to my house without getting his semi stuck in snow so I had him meet me at another address in the same town I live in.i was likeba kid in a candy storeban honestly I didnt take the time looking atvl directions an didnt an didnt have any problems putting it together.took maybe 40min maybe.an the pieces are not rubber it just looked like it .
post #7 of 19 Old 01-12-2014, 03:04 AM Thread Starter
Before I put it on I greased the snot out of it not only that I thought the squeking noise at first was coming from the adgustment gear so I greased it also even thou that wasnt were its coming from its deffntly between the chute an housing .
post #8 of 19 Old 01-12-2014, 07:57 AM
Likes (Given): 266
Not sure what to tell you. To me, squeaking says it's binding. Does it turn real easily?
Snowmann has weighed in on this and he works for Ariens. He will help you figure it out.
Larry
post #9 of 19 Old 01-12-2014, 08:11 AM Thread Starter
Turns really easy doesnt seem to be binding at all.i can jiggle the base of the chute by hand .theres a lil play.i wish I had another ariens to compare but they fly like hot cakes once the littlest bit of snow thats why I had to order one.even my local dealer couldnt get me anything on order other than a compact or deluxe 24 an thats it.
post #10 of 19 Old 01-12-2014, 08:15 AM Thread Starter
Once I get a chance I will go over to were its at an try loosening it more an see what happens.thanks appreciate all the help I can get .
