24" SHO Heated Handgrips Don't Work - Snowblower Forum : Snow Blower Forums
post #1 of 22 Old 01-05-2018, 02:39 PM Thread Starter
Hi......................used my 2 year old 24" SHO yesterday and neither handgrip gets warm..............anyone have this problem? (and yes, the switch is on )
scotzz is offline
post #2 of 22 Old 01-05-2018, 04:20 PM
jburson250's Avatar
Thanks (Given): 14
Likes (Received): 11
And the plugs are connected?
Sorry Scot, just had to ask the other half of obvious - you got the first half.
Here's a wiring diagram for my Pro 28 - too lazy to figure out your model #:
https://parts.ariens.com/partlookup_...000%7c%7econ/y
Most hand warmers are in series, i.e. if one goes out, they both go out. A more likely failure, though, is the switch. If similar to mine - a 2014 - yours might be an uncovered toggle switch.
I'm an old fart, so hand warmers are mission critical. I keep a new switch in my spare parts box.
Good luck!
Jim in NH
'14 Ariens Pro 28 926038
'18 Ariens Classic 24 920025
jburson250 is offline
post #3 of 22 Old 01-05-2018, 04:46 PM
Likes (Received): 66
When my Hand-Warmers clunked out . . . . it was the "Connector" between the alternator and the fuse that had died.
In his wisdom, the Manufacturer had located this Connector right at the bottom of a drip loop where it would accumulate salty water to accelerate the corrosion of the chintzey aluminum contacts within the Connector.
I spent quite a bit of time diagnosing this problem, and only when I went back to verify my assumptions did I discover the disconnect between the engine and the HandGrips.
Hardwired, they've been working fine . . . . nothing wrong with the Heated Hand Grips.
The Connector is there solely to simplify the manufacturing process.
Vermont007 is offline
post #4 of 22 Old 01-05-2018, 06:28 PM Thread Starter
Good luck!
Yes, mine is the uncovered toggle switch. Leads seem to be connected but I'll have to double check
scotzz is offline
post #5 of 22 Old 01-05-2018, 06:33 PM Thread Starter
Good luck!
Thanks for the parts list
scotzz is offline
post #6 of 22 Old 01-05-2018, 08:05 PM
jburson250's Avatar
Thanks (Given): 14
I added this to my Pro 28 when I first got it. Ordered 3, got 1 left.
My switch is still the original one - maybe the cover helped extend it's life.
Here's where to get a new one:
https://www.jackssmallengines.com/ja...riens/02485700
You can go back to Jack's home page, enter your model #, and find just about any part on earth for your blower.
Best Regards
Jim in NH
post #7 of 22 Old 01-06-2018, 06:10 PM Thread Starter
well...............I tested the switch and it is ok. No power coming through the leads to the switch with the engine running. I am not sure of the wiring. I assume power from the alternator comes up the right side of the handle to power both the light and hand grips. If this is the case then there is a problem with the wiring under the dash. How many volts should be coming through the leads?
scotzz is offline
post #8 of 22 Old 01-06-2018, 07:26 PM Thread Starter
Actually I am testing the leads incorrectly. Should I be checking voltage from the yellow lead to ground?
scotzz is offline
post #9 of 22 Old 01-06-2018, 07:49 PM
jburson250's Avatar
Thanks (Given): 14
@scotzz go to parts.ariens.com, put your model # in, and you'll get some diagrams.
One of these will be the wiring diagram, similar to the one in the link I included in Post #2.
There you'll find the wire colors. These engines usually produce 12-18 volts AC.
Does your light work? If not you may have a bigger problem.
Your blower has a 3 year warranty. Call Ariens for advice. Phone #'s in your owner manual.
Jim in NH
post #10 of 22 Old 01-07-2018, 08:31 AM Thread Starter
I looked at the wiring diagram from the Ariens site but it doesn't match completely. They show a single yellow lead coming into the switch but my snowblower has a two yellow leads piggybacked. Each grip has a yellow and brown lead. I assume the brown are ground leads? What do the brown ground leads attach to? Since the engine is aluminum I assume ground leads connect to the alternator?
scotzz is offline
