1974 Ariens 6hp, I saved from salvage yard - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 01-07-2018, 02:12 AM Thread Starter
I have spent a lot of elbow grease to get the machine functional would just. Like help increasing performance.
Soup is offline
Likes classiccat, detdrbuzzard liked this post
post #2 of 17 Old 01-07-2018, 02:14 AM Thread Starter
Serial # 910019
Soup is offline
post #3 of 17 Old 01-07-2018, 11:56 AM
stromr's Avatar
Thanks (Received): 38
Likes (Received): 63
You could put a modern, larger engine on it for the increased torque and horsepower. Maybe an impellor kit too. The design of these was and is the standard of the industry. Modern tires like X-Trac or Snow Hog would help with the traction. There's a reason you still see so many of these older machines still in use, they were made heavy duty to last for decades, but engines, tires and impellor kits do help.
stromr is offline
post #4 of 17 Old 01-07-2018, 11:24 PM
Ian Ariens 924's Avatar
Thanks (Given): 14
Thanks (Received): 7
Likes (Given): 30
Likes (Received): 17
I agree with the impellor kit and the tires have chains,you should be fine.Hope you get lots of use out of it,these models last forever
I really enjoy seeing the older Ariens units getting saved and being used.
Ariens 924116 10 hp 28”
Ariens 924024 8 hp 32” now a 10 hp
Ariens 910008 7 hp 24”
Ian Ariens 924 is online now
post #5 of 17 Old 01-07-2018, 11:38 PM
Thanks (Received): 157
Likes (Given): 1638
How exactly is your machine under-performing?
+1 on adding rubber to the impeller if you haven't already.
I recently grabbed a '71 524 and it exceeded my expectations by a mile.
The engine needed a minor overhaul (fuel system, refreshed the ignition, valve job, new head gasket).
classiccat is online now
post #6 of 17 Old 01-08-2018, 02:20 AM Thread Starter
I would like to figure out how to post video
Soup is offline
post #7 of 17 Old 01-08-2018, 02:23 AM Thread Starter
Here
Soup is offline
post #8 of 17 Old 01-08-2018, 02:32 AM Thread Starter
Here is Scrap iron throwing snow
Soup is offline
post #9 of 17 Old 01-08-2018, 02:51 AM Thread Starter
Well the photo loaded, but won't play I see I have work to do on this video.
Soup is offline
post #10 of 17 Old 01-08-2018, 03:03 AM Thread Starter
I cleaned points, carburetor, all drive was disassembled and regressed as I installed a new friction disc.
I still have some carb issues needs a little tweak
I would like to add the 3 and 1/4 pully on the crank. I ajusted the friction wheel to give me more reverse speed while taking away from forward gear speed. I now am in need of a good service manual so I have torque specs and other performance/ maintenance procedures, maybe even adressing the timing.
Just want a scrap iron machine out perform my neighbors through away blowers that are less than 5 years old, I can and will succeed.
Soup is offline
