Autoturn bad why continue for 3 years? - Snowblower Forum : Snow Blower Forums
post #1 of 22 Old 01-08-2018, 10:22 AM Thread Starter
Thanks (Given): 95
Thanks (Received): 192
Likes (Given): 73
Likes (Received): 436
I read sscotsman Ariens blog.
For the first 3 years Ariens had the Autoturn feature they had problems with it.
Then why did they continue it for 3 years? Did it take that long for the problems to show?
If it took that long for them to come up with a fix then they should have discontinued it until they had a fix rather than to continue to produce a problem.
post #2 of 22 Old 01-08-2018, 10:35 AM
Thanks (Received): 29
Likes (Received): 41
Because it worked as it should. They have made changes to help with wondering but it took weight off the front that people like. Its more of a compromise either way. But both setups have work fine you just need to figure out the best way to use it on your terrain.
351beno is offline
post #3 of 22 Old 01-08-2018, 11:30 AM
We just bought a RapidTrak with autoturn and it works great.
If Ariens made changes wouldn’t the assembly have a different part number?
CarbineMan is offline
post #4 of 22 Old 01-08-2018, 11:39 PM
GoBlowSnow's Avatar
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 268
Not everyone had issues with the Auto Turn.
GoBlowSnow is offline
post #5 of 22 Old 01-09-2018, 08:16 AM
Thanks (Given): 19
Thanks (Received): 48
Likes (Given): 107
Likes (Received): 221
The AutoTurn on my Ariens Hydro Pro 28 works great. Very easy to turn and works as advertised in a few inches or more that foot of snow.
russ01915 is offline
post #6 of 22 Old 01-09-2018, 08:28 AM
jburson250's Avatar
Thanks (Given): 14
Likes (Received): 11
AutoTurn on my Pro 28 works great. My driveway is old and lumpy, so I'm using poly skids this winter. New driveway coming summer '18.
Jim in NH
'14 Ariens Pro 28 926038
'18 Ariens Classic 24 920025
jburson250 is offline
post #7 of 22 Old 01-09-2018, 09:24 AM
Thanks (Given): 101
Likes (Given): 261
Likes (Received): 143
I've fitted poly skids to my 24" SHO within the past week. No more jumping around - - completely eliminated.
uberT is online now
post #8 of 22 Old 01-09-2018, 03:12 PM
Ariens hydro pro's Avatar
Thanks (Received): 26
Likes (Received): 52
When I was going fast down the driveway in 2 inches of snow it was a problem, then I put wheels on the front. It's awesome now.
If you have issues find a way to reduce the resistance on the skids...
Bob
Ariens hydro pro is offline
post #9 of 22 Old 01-09-2018, 03:27 PM
aldfam4's Avatar
Thanks (Given): 247
Thanks (Received): 46
Likes (Given): 674
Likes (Received): 124
Just wondering, I don't have a newer machine, my toro is 27 years old, my Ariens is 23 years old and my Craftsman is 18 years old, but this auto turn situation - does it relate to trac snow blowers, wheeled snow blowers, or both? Would the ArmorSkids help with the auto turn problems? Just seeking knowledge.
aldfam4 is offline
post #10 of 22 Old 01-09-2018, 03:46 PM
Thanks (Given): 251
Likes (Given): 71
Likes (Received): 56
I think that new Ariens auto turn track is going to be a big win for Ariens.
barney is offline
