Winterized? - Snowblower Forum : Snow Blower Forums
post #1 of 24 Old 01-23-2014, 04:37 PM Thread Starter
Winterized?
Just wonder, when Lauson advertised their engines as 'Winterized', exactly what does that entails? Is it just the heater box around the carb?
-Ken
2011 John Deere 1330se
WestminsterFJR is offline
post #2 of 24 Old 01-23-2014, 05:48 PM
Likes (Received): 42
Exactly...and no air filter... logic being it's for snow, so little or no dirt/dust to worry about. MH
motorhead64 is offline
post #3 of 24 Old 01-23-2014, 06:16 PM Thread Starter
Was the heater box there to protect the links and butterflies from freezing up? Mine has a label that warns against using the heater box in temps above 32F.
-Ken
post #4 of 24 Old 01-23-2014, 06:42 PM
Not sure why that would be.? The heater box does keep linkage from freezing, also warms up the engine faster. I never take mine off on any of my other blowers. MH
post #5 of 24 Old 01-23-2014, 09:21 PM
Thanks (Received): 143
Likes (Received): 297
How often would you have snow above freezing?
post #6 of 24 Old 01-23-2014, 10:45 PM
Thanks (Given): 72
Thanks (Received): 397
Likes (Given): 182
Likes (Received): 930
It can happen..in late fall and late winter. October and March/April.
although usually if its above freezing and snowing, say 34 degrees, the snow is very wet and slushy, and doesnt build up thick enough to require the use of a snowblower..you dont get 6" of snow at 34 degrees..you get a thin layer of very wet slush..no snowblower required.
So it can, rarely, snow above freezing.
but using the snowblower above freezing is ever rarer..
so rare in fact, that IMO it statistically never happens.
sscotsman is offline
post #7 of 24 Old 01-23-2014, 11:31 PM
Thanks (Received): 22
Likes (Received): 13
It happens all the time, It snows over night when the temps are hovering in the 20's, then during the day the temp gets in the mid 30's, you need to blow snow and it's above freezing, not so uncommon. Short durations of sunlight during the day as the temps get into the mid thirties isn't necessarily enough to melt the snow, especially with the lower trajectory of the winter sun.
EDIT: After I wrote this I realized that tonight is perfect example of the situation I'm describing. It's -8 degrees right now with a 50% chance of snow, tomorrow's high is 36 degrees. So if it snows tonight folks all over the twin cities could be snowblowing in temperatures above freezing.
superedge88 is offline
post #8 of 24 Old 01-24-2014, 11:16 AM
Like the other guys said - you'd be surprised. Get that late April Minnesota snow one night, 6" + of wet stuff, and then next day it's sunny and 50 degree's. The snow has to go..... Except you're doing it in shorts!
2014 Ariens 921032 (Deluxe 30")
291cc
Anti-Auger Lock Mod applied
DOT reflective tape
ArmorSkids (soon)
Upgraded grips (soon)
Eventually.....LED fog light.
MinnTim is offline
post #9 of 24 Old 01-24-2014, 05:25 PM
I can see where those scenarios may happen, but unless you do not encounter a refreeze situation, or accumulations that the warming will not take care of, I usually don't operate the machine. I guess I am inherently lazy in that way.
The only time I might run it in t-shirt weather, is to move it from the garage to the barn. And then maybe to run the fuel tank dry.
post #10 of 24 Old 01-24-2014, 05:47 PM
Thanks (Received): 28
Likes (Received): 58
If you look closely at the "winterized" they not only had the carb heat box which also enclosed part of the muffler to give heat but there is also a wrap around tin shield blocking the fins of the cylinder and motorto keep heat in and snow out. It would wrap from the carb box accrossnthe crank side of the motor and behind the gas tank.
td5771 is offline
