What is the best led mod for 28=delux - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 01-24-2018, 01:15 AM Thread Starter
Cool What is the best led mod for 28=delux
I am looking for the best led mod for my 28/deluxe. I have seen a bunch but not sure which is the best. I like the one with the 2 on the auger housing.
Barry MacEwen is offline
post #2 of 8 Old 01-24-2018, 03:37 AM
Ariens hydro pro's Avatar
Thanks (Received): 26
Likes (Received): 52
I feel the auger housing is a bad spot. Because....
1. You can't see the sides of your machine. For example, your tires are in a bad spot going down the sidewalk.
2. I have went thru snow higher that the bucket. Going over the bucket straight into the lights is abusive to your lights.
Bob
Ariens hydro pro is online now
post #3 of 8 Old 01-24-2018, 05:54 AM
Led light on auger
Hi.
The auger housing is not a bad place to install your led light. That is where I installed mine and it is raised several inches above the auger housing. Also, I have installed two side marker lights on my snow blower. This gives increased visibility from both sides. I have posted a image with the auger mounted Led in the gallery section.
Mate from Virginia is offline
post #4 of 8 Old 01-24-2018, 09:47 AM
jburson250's Avatar
Thanks (Given): 14
Likes (Received): 11
And if you ever need to separate the tractor from the bucket - i.e. belt change - you've now got wiring that'll need to be disconnected, one way or another.
Jim in NH
'14 Ariens Pro 28 926038
'18 Ariens Classic 24 920025
jburson250 is offline
post #5 of 8 Old 01-24-2018, 10:44 AM
Thanks (Received): 354
Likes (Given): 151
Likes (Received): 788
Non-issue, IMO, because:
https://www.google.com/search?biw=12...&q=2-wire+plug
post #6 of 8 Old 01-24-2018, 10:53 AM
Thanks (Given): 21
Thanks (Received): 63
Likes (Given): 254
Likes (Received): 239
What's the criteria for "best"?
jsup is offline
post #7 of 8 Old 01-24-2018, 01:31 PM
Auger mounted light
You can install a quick disconnect so you can remove the light if you have to turn the snow blower on its auger housing. I have posted a image in the gallery section.
post #8 of 8 Old 01-26-2018, 08:15 PM Thread Starter
The best would be the best for no flicker as well easiest install. Lights would be on the auger housing
