1971 Ariens Sno-Thro primer/choke thing? - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 01-27-2018, 01:49 PM Thread Starter
Likes (Received): 22
I have a 1971-ish Ariens Sno-Thro which has a 7HP Tecumseh and appears to be a 24" clearing. There is this spring-loaded black knob that says "Primer" on it and I have no clue as to how it even works. All it appears to do is choke the carburetor. Does anyone have any input on this old style primer?
FlamingSpaghetti is offline
post #2 of 14 Old 01-27-2018, 02:41 PM
Thanks (Received): 157
Likes (Given): 1638
Yep, rather than forcing air into the float bowl with a primer bulb (which in turn forces fuel up through the emulsion tube and into the venturi), holding the button in during the intake stroke creates a vacuum in the throttle body (which in turn sucks fuel up the emulsion tube).
It actually works quite well. Make sure the mating surfaces are clean.
To be kind to these old ignitions, ground the ignition (throttle in "off" position) when giving it the primer pull (you don't have to pull hard either)...then release the prime-button, move to half throttle for the starting pull.
classiccat is online now
Likes Grunt, db130 liked this post
post #3 of 14 Old 01-27-2018, 04:01 PM Thread Starter
Thanks for this valuable information. This tells me that the spring on my primer is on the wrong side and should be on the outside of the heater box, is this correct?
post #4 of 14 Old 01-27-2018, 04:02 PM
Thanks (Given): 72
Thanks (Received): 170
Likes (Given): 63
Likes (Received): 583
Should be on the outside....yes......
cranman is online now
post #5 of 14 Old 01-27-2018, 04:09 PM
Likes (Given): 1638
Not a problem!
Correct, spring on the outside of the bracket.
Here's a shot of mine (prior to refurb) with the heater-box removed:
post #6 of 14 Old 01-27-2018, 05:26 PM
Thanks (Given): 511
Thanks (Received): 682
Likes (Given): 3849
Likes (Received): 1479
He shows how to do it about a minute in.
post #7 of 14 Old 01-27-2018, 06:54 PM
scrappy's Avatar
Thanks (Received): 39
Likes (Given): 36
Likes (Received): 91
Agree!
How ever, for some reason my self and dad removed the primer on his '67 tecumseh. It has always started with a few pulls. It could also be the machine was always in a attached garage. So never below 0 degree cold starts. A shot of ether won't hurt either. Any ways that primer is long gone. I would buy one just to put it back to original.
scrappy is offline
post #8 of 14 Old 01-27-2018, 07:23 PM
Likes (Given): 1638
Originally Posted by scrappy View Post
Agree!
here ya go brother scrappy.
referenced my '71 H50
choke plate
https://www.ebay.com/itm/Tecumseh-32...oAAOSwKXdaTsjR
spring (reference only... so you can grab one from the parts bin instead of getting robbed blind)
https://www.ebay.com/itm/Tecumseh-Pa...ss!12306!US!-1
bracket
https://www.ebay.com/itm/Tecumseh-Ca...MAAOSwnVhaSljk
primer knob
https://www.ebay.com/itm/NEW-Tecumse...ss!12306!US!-1
Thanks scrappy thanked for this post
post #9 of 14 Old 01-27-2018, 07:39 PM
Thanks (Given): 10
Likes (Received): 17
Its missing the round air filter mount bracket, which would of been their since its a 10000 series and would have been readily available to swap to a summer engine for attachments.
It would have originally looked like the engine in this photo, which was my original Tecumseh from my 1971 Ariens 10000 series. (heater box removed to show how it looks under their).
Fourth photo after photos of primer with air filter mount plate shows engine in summer mode with mower attachment.
Last photo in winter mode round bracket on behind heater box.
The decal on the heater box (often worn off or faded from age and weather) as well as in the engines operators manual would have said at 10 degree and below use the primer by pushing and holding it and turning over the engine 3 times slowly to prime. Those primers really aren't needed unless its that cold, they start very well just on choke up above 10 degrees and a shot of starting fluid also would work just as well/better than the old spring loaded primer.
Name:	Tecumseh 71 blown before dismantle side view carb.jpe
ID:	128449   Click image for larger version
Name:	Tecumseh H70 3a.JPG
ID:	128505   Click image for larger version
Name:	Tecumseh H70 5a.JPG
ID:	128513   Click image for larger version
Name:	Ariens 10000 Trac Team rotary 12.JPG
ID:	128521   Click image for larger version
Name:	1971 Ariens Sno-Thro 7-24 11.JPG
FearlessFront is offline
post #10 of 14 Old 01-27-2018, 08:02 PM
Likes (Given): 1638
Is the filter mount plate needed if you only have a hot-box (winter use)?
Man, that's one sweet setup FF! How does it cut?
