Engine stalled and will not start again - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 01-25-2014, 05:40 PM Thread Starter
Hi All,
I have a new 2014 Platinum 24 with the Ariens AX291 engine. I have used the unit twice before to clear snow and it ran flawlessly. Today, the engine started on the first pull and when I moved the choke from the Start to the Run position, the engine stalled. My subsequent attempts to restart the engine have been unsuccessful. Since my dealer is closed until Monday, do you guys have any suggestions on anything that I can try to get the engine restarted? Some things I have tried:
  • I'm using premium fuel from Shell so there is no ethanol content. The fuel is fresh and was pumped a few days ago.
  • Thinking that the engine may have been flooded, I let the unit sit for about an hour, removed the spark plug, shut off the fuel supply, can cranked the engine a few times.
  • I tried using both recoil and electric start.
Thanks in advance!
Darren is offline
post #2 of 12 Old 01-25-2014, 06:11 PM
Thanks (Received): 28
Likes (Received): 58
Start with removing the plug, hooking the plug wire to it and hold it against the motor whole you crank it to check for spark. Keep in mind plugs can get fouled to the point they wont spark at all even after you clean them. Before the spark test flea. It and make a few swipes with a piece of sand paper in the plug gap. Not too much or you will change the gap.
td5771 is offline
post #3 of 12 Old 01-25-2014, 06:12 PM
Have you tried putting the choke back on?
Did you turn the fuel valve on?
post #4 of 12 Old 01-25-2014, 06:52 PM
Likes (Received): 10
Some engines require the choke be left 3/4 on for a bit and then moved to 1/2 and then off. I start my AX208 (Path-Pro) on 3/4 choke and it starts first pull every time. I leave it on 3/4 choke for a bit and then turn it off. If I turn the choke off immediately, the engine will stall every time.
Make sure fuel valve is on and then try starting it on 3/4 choke. If it starts, leave it run a bit on 3/4 choke before turning the choke off.
JRHAWK9 is offline
post #5 of 12 Old 01-25-2014, 07:34 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
Was the plug wet ?? If the plug wasn't wet you might be too lean rather than flooded.
Start at the beginning. Put on the choke, prime it once or twice depending on what you usually do and try starting it. After a few tires if it hasn't started, pull the plug and see if it's wet. If it's wet you're getting fuel and it's likely flooded. If it's not wet there might be a restriction in the fuel line or carb.
post #6 of 12 Old 01-25-2014, 08:11 PM Thread Starter
I checked that the valve was on and tried a few different positions on the choke. I also ensured that the key was in and that the stop/run switch was in the run position.
Darren is offline
post #7 of 12 Old 01-25-2014, 08:17 PM Thread Starter
Hi,
I assume that you're suggesting trying the procedure from the video below:
I just got back from giving it a try and I did not see any spark. I will try again tomorrow since it was starting to get too cold in my garage (it's -14 C here and dropping).
Thanks for the suggestion.
Darren is offline
post #8 of 12 Old 01-25-2014, 08:24 PM Thread Starter
The plug was not particularly wet when I removed it but to be honest, I'm not sure what a wet plug from a flooded engine should look like. In any case, I followed the instructions from Snow Flooding Guideline.
Darren is offline
post #9 of 12 Old 01-25-2014, 08:33 PM
If you cleaned and scuffed the plug and had no spark you need to check the kill switches on you model. Key, on some the throttle all the way in the slowest position is a kill switch. I am not an expert on your particular machine. Someone with one can help out.
Look for ice or water build up in the areas of the kill switches or safety. May be shorting it out.
td5771 is offline
post #10 of 12 Old 01-25-2014, 10:38 PM
Thanks (Given): 590
Likes (Given): 4371
Or the wiring might have a small area that melted and shorted which will kill the spark as will the wire grounding out if the insulation on it gets cut or worn away and it's able to touch metal.
