replacment engine ariens st824 - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 01-26-2014, 05:36 PM Thread Starter
hello
a question from norway.
sorry for my bad language.
i have a very old st824 snow blower with blown engine.
and i am trying to find a replacment engine. but it seems the lenght from the base up to senter og the shaft is 105mm(4,13 inches) on my old engine.
and on replacment engine i can find in norway it is 133mm(5,24inches).
do i only need a bit larger belts? with new engine.
the engines who are avalible in norway are loncin,sierra,and honda copy.
norsk viking is offline
post #2 of 13 Old 01-26-2014, 05:52 PM
1" taller is going me mean you will need belts 2" longer. You will probably have to do something with the belt cover too if you do that.
I switched my HM80 for a Honda clone and the shaft height was the same. In my case though I had a 3/4" shaft on the new engine vs a 1" shaft on the old one so I needed new pulleys as well.
post #3 of 13 Old 01-26-2014, 06:03 PM
Thanks (Received): 28
Likes (Received): 58
It would be more money the 11 hp predator honda clone has a crankshafts canter of 5.25 inches from base to center. Maybe your honda clone or loncin is the same?
td5771 is offline
post #4 of 13 Old 01-26-2014, 06:11 PM Thread Starter
that could be the same motors.i cant find 105mm(4,13 inches) engines.
what engines are avalible in 105mm(4,13 inches) form base to senter og shaft?
with 1 inch shaft? if i dont find in norway i can use jetcarrier to ship to norway.
post #5 of 13 Old 01-26-2014, 06:23 PM
I apologize, I read your lost too quickly. The standard 212 cc 6.5 Hp predator engine is 4.17 inches to crank centerline.
Loncin HAS to have a similar engine. Let me check.
td5771 is offline
post #6 of 13 Old 01-26-2014, 06:46 PM
The loncin 170 engine is 105 mm centerline.
I think the 175 is a step up and is 133 mm.
The 170 is about 7hp. I would contact a loncin dealer as what I found is just online. You need to be positive
td5771 is offline
post #7 of 13 Old 01-26-2014, 06:49 PM Thread Starter
whas this a 8hp honda clone?
post #8 of 13 Old 01-26-2014, 06:56 PM Thread Starter
ok. si i cant just putt a 133mm centerline engine with a new pulley or longer belts? i hoped i could do a quick and easy engine swap.i can buy a used engine but it cost 651 dollar. and a new china engine cost 489dollars.
post #9 of 13 Old 01-26-2014, 07:01 PM
Sure you can. I believe this one will bolt right on. I just want you to double check with your engine seller.
LC170F£¨D£©S - Loncin lndustries
Its the 170 and should have a 105 mm centerline for the crank.
You have to check the crankshafts diameter as well.
td5771 is offline
post #10 of 13 Old 01-26-2014, 07:06 PM
The bad part is it is only around 6 Hp. But you wont have to change anything.
good part is it is a snowblower winterized engine.
You can Go bigger and change the belts and maybe the pulley
td5771 is offline
