weight kit - Snowblower Forum : Snow Blower Forums
post #1 of 24 Old 02-13-2018, 05:04 PM Thread Starter
1132le's Avatar
Thanks (Given): 28
Likes (Given): 60
Likes (Received): 190
weight kit
Saw some weights out for the trash today pulled over and grabbed them was hoping they were 2.5 lbs but they were only 1 1/4 lbs each 8 total
used the factory weight holes on each side
Had some old big washers from where i forget worked perfect
10 lbs on the bucket now
bucket was very light in the front
love to repurpose things
ID:	132361   Click image for larger version
1132le is offline
post #2 of 24 Old 02-13-2018, 05:16 PM
Thanks (Given): 511
Thanks (Received): 682
Likes (Given): 3849
Likes (Received): 1479
Good job. I might suggest a little paint or PlastiKote when it's warm enough so as to keep the washers from rusting.
Likes northframingham, 1132le liked this post
post #3 of 24 Old 02-13-2018, 07:40 PM
Thanks (Given): 118
Thanks (Received): 277
Likes (Given): 358
Likes (Received): 633
Cool! That's a much nicer price than the Ariens weights!
Are there some washers underneath the bucket, to help spread out the load from the bolts? The bucket sheetmetal is presumably unsupported under the bolt head's area, due to the big hole in the weights.
RedOctobyr is offline
post #4 of 24 Old 02-13-2018, 08:16 PM
Thanks (Given): 144
Thanks (Received): 275
Likes (Given): 380
Likes (Received): 927
I remember a JD garden tractor I had. Had a 54" power angle, power lift plow on it. I had 50# weights on the wheels, 4 suitcase weights and a couple of Ford 460 heads strapped on top of them for weights. Whatever gets the job done. Doesn't have to be pretty. Just has to work.
post #5 of 24 Old 02-13-2018, 10:00 PM
Thanks (Received): 36
Likes (Given): 57
Likes (Received): 84
I started using old/worn Highway Plow Cutting edges. They start off as 8" or 10" wide steel plates. About 10' and up longer. Cut to length, (24", 28" and up,,custom sized), and bolted underneath the tub, rather than on top, so not to worry about finished edges or painting. Very dense material and plentiful this time of year.....
GLuck, Jay
JayzAuto1 is offline
Thanks guybb3 thanked for this post
Likes guybb3 liked this post
post #6 of 24 Old 02-14-2018, 09:25 AM
Thanks (Given): 14
Likes (Given): 14
Likes (Received): 25
I can tell you on my Hydro Pro 28 that I just sold, adding 25 Ibs did nothing to help me keep the front bucket down. It was like a teeter-totter no matter how much I added. On my older Platinum 30 before they moved the axle location the weight helped significantly. Only problem with that model was the friction disc setup that was too weak.
Honda HSS1332ATD
Freddy Ford is offline
post #7 of 24 Old 02-16-2018, 10:35 PM Thread Starter
1132le's Avatar
Thanks (Given): 28
Likes (Given): 60
washers painted semi gloss black
1132le is offline
post #8 of 24 Old 02-17-2018, 07:36 AM
Thanks (Given): 144
Likes (Given): 380
How was the friction system too weak? What did it do or not do that you think it was weak?
post #9 of 24 Old 02-17-2018, 07:51 AM
aldfam4's Avatar
Thanks (Given): 204
Thanks (Received): 41
Likes (Given): 579
Likes (Received): 110
I really like this idea, 1132le. I have an older Ariens St10-28, and she tends to ride up on the EOD snow. I have the armorskids on there and really like them but will give your idea a try with a little variation. I finally got to put that tach on my snowblower (another post that you responded to) and after warming up the blower, I got a reading of 3550 rpms, just short of the recommended 3600 rpms. I can live with small difference for now!
Ariens - 924086 - ST1028
Craftsman - 88934 - 10HP 28"
Toro - CCR 3650
Toro - CCR 2000
aldfam4 is offline
post #10 of 24 Old 02-17-2018, 07:58 AM
northframingham's Avatar
Thanks (Given): 29
Likes (Given): 53
On 01/15/2018 I took delivery of a ARIENS Hydro Pro 28"
I added the ARMORskids and (2) 10# weight kits.
Since then I have only had a little slush a few times in a month.
Hopefully with the snow coming tonight/tomorrow I can test it out finally!
2015 Ariens Hydro Pro 28" w/ B&S 420cc
w/(2) 10# weight kits and ArmorSkids
2012 Snapper SS822E 22" w/ B&S 205cc
northframingham is offline
