11 Briggs on a 924050 - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 04-01-2018, 06:33 PM Thread Starter
Jackmels's Avatar
Thanks (Given): 108
Thanks (Received): 164
Likes (Given): 347
Likes (Received): 648
For the Last 6 months, I've been Tripping over this 11 Briggs, and Decided to Drop it on a 924050 I had Out Back. Holes were Factory Drilled for the Briggs Footprint. Had to Mod the Crank Linkage, and Size Belts, as the Crank Height is Different. Also Modded a Craftsman Belt Cover to Work. Still Needs Some Cleanup, Chute Mod, and Impeller Seal.
ID:	141057   Click image for larger version
Jackmels is offline
Thanks Fred9 thanked for this post
Likes classiccat, Dauntae liked this post
post #2 of 6 Old 04-01-2018, 06:41 PM
Thanks (Given): 72
Thanks (Received): 170
Likes (Given): 63
Likes (Received): 584
Very cool Jack...I remember you having that engine when I visited last. That should really throw the white stuff! I've been toying with the idea of doing the same swap with an 11 Briggs that burns oil some but runs strong.
cranman is online now
post #3 of 6 Old 04-01-2018, 08:02 PM
Thanks (Given): 89
Thanks (Received): 180
Likes (Given): 69
Likes (Received): 409
Jack, how do you find the right belt size when you do a modification? Do you try different belts you have around? Do you use a string or rope around the pulleys and then measure?
I have a set of old belts, 3L, 4L, 5L, that are purposely too long and I've cut. I know the length of these belts, I then track around the pulleys and measure how much I have left and subtract.
JLawrence08648 is offline
post #4 of 6 Old 04-01-2018, 08:20 PM
Thanks (Received): 157
Likes (Given): 1645
Likes (Received): 382
Oh man... that's going to be a monster Jack!
classiccat is online now
post #5 of 6 Old 04-01-2018, 08:59 PM Thread Starter
Jackmels's Avatar
Thanks (Given): 108
Likes (Given): 347
I Save Good Belts and Other Useful Parts before Scrapping Machines. I Keep a Good Assortment on Hand.
Jackmels is offline
post #6 of 6 Old 04-02-2018, 03:07 AM
Likes (Given): 36
Likes (Received): 34
st1136 belts will work fine, that motor came on the 1136 and the only differences between the machines beltwise is crank height
arienskids is online now
