42 year old Ariens some help Please - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 01-27-2019, 03:40 PM Thread Starter
Thanks (Given): 49
Thanks (Received): 8
Likes (Received): 7
Ariens 1977 purchase ST 24 model 924032 serial 008001 (this is important #)
Hello I believe this Ariens is only on its' 2nd set of belts as my Dad was original purchaser, & I was original operator (LOL) & I have only 1 set of old belts.
1.) I am getting some discrepancies about the belt sizes original belt # 72098 I believe is 3/8 X 33... but I have found some to be 34 & 34 1/2 long???
2.) Original belt # 72108 I believe is 1/2 X 37..... but I have found some to be 36 1/2 & 37 long??
> what should the correct lengths be for each belt?
> 72108 may now be 07210800 & 72098 may now be 07232100 ??
3.) I also am running the original Friction Disc #3003. I am unsure whether I should buy an Arien's stamped Friction Disc or buy an aftermarket disc? I kind of doubt Ariens makes them. Any thoughts about this too?
Thank You For the help
ron3033
ron3033 is offline
post #2 of 13 Old 01-27-2019, 05:33 PM
Thanks (Given): 66
Thanks (Received): 161
Likes (Given): 62
Likes (Received): 571
Those 924 twin sticks had two different belt sizes....the small three lug wheels have shorter belts then the larger four bolt wheels. The difference is in the bucket attachment lugs on the big wheel buckets being moved upward to make up for the larger wheels.
cranman is offline
Thanks ron3033 thanked for this post
post #3 of 13 Old 01-27-2019, 05:37 PM
Thanks (Given): 19
Thanks (Received): 47
Likes (Given): 102
Likes (Received): 217
Take them off and bring them to a auto parts store. They usually have some kind of tool to measure them.
russ01915 is offline
post #4 of 13 Old 01-27-2019, 06:48 PM
Thanks (Given): 510
Thanks (Received): 681
Likes (Given): 3844
Likes (Received): 1478
Ariens friction disc # 00300300 or Stens 240-394 I get mine at Oreilly Auto Parts # 7-04211 for $15 and they come with a lifetime warranty. I've had no fitment issues or operational complaints. You will likely need to call or drop in and have one ordered from the distribution center in your area as they usually aren't stocked in stores.
Still working on the belts. Original numbers according to your serial number.
Auger belt 07210800
Drive Belt 07209800
post #5 of 13 Old 01-27-2019, 07:03 PM
SimplicitySolid22's Avatar
Thanks (Given): 51
Thanks (Received): 60
Likes (Given): 56
Likes (Received): 91
On72108 I have also seen a 1/2' X 36.7". Which actually might be perfect....Right down the middle.
https://www.ebay.com/i/132055871034?chn=ps
SimplicitySolid22 is offline
post #6 of 13 Old 01-27-2019, 07:20 PM
db130's Avatar
Thanks (Given): 15
Thanks (Received): 64
Likes (Given): 204
Likes (Received): 139
Ariens still very much makes the 3003 friction wheel. Why wouldn't they? The 924 series sold for over 3 decades.
db130 is offline
post #7 of 13 Old 01-27-2019, 07:45 PM
AL-
AL-'s Avatar
Thanks (Given): 7
Likes (Received): 29
ron3033
I don't know if you can get NOS or not, if you could the rubber might be frail. I bought some NOS pads for my old Simplicity and the rubber cracked.
AL- is offline
post #8 of 13 Old 01-28-2019, 10:32 AM Thread Starter
Thanks (Given): 49
Likes (Received): 7
Auger belt 07210800
Drive Belt 07209800
Hi Thank You 72098 belt (3/8 X 33) was listed at Ariens Parts store as 07232100 I am worried it may be an error or wrong size.
https://parts.ariens.com/partlookup_...m?aribrand=ARN
belts are listed this is 7hp 008001 serial that makes a difference 2 models that year for 7hp. Not sure what is different.
ron3033 is offline
post #9 of 13 Old 01-28-2019, 10:38 AM Thread Starter
Thanks (Given): 49
Likes (Received): 7
Good point about the rubber on the disc. Thanks for the insight.
ron3033 is offline
post #10 of 13 Old 01-28-2019, 10:44 AM Thread Starter
Thanks (Given): 49
Likes (Received): 7
I have to go out and look at the wheels now ... but it is -18 Fahrenheit LOL! I guess that is why there is 0 to 8000 and 8001 and above. There are are other parts different too when I looked through the ariens parts store
Thanks for the info. Much appreciated.
ron3033 is offline
